Question about Dishwashers
Zanussi DX6452 not heating up, replaced heating element but still no joy-please help!! What else could I look for?
Could be an element fault but check the pcb tracks on the main pcb that go to the heating element as this is a common fault/issue. track will be blown around relay connection as a rule.
Posted on Aug 15, 2010
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
Dx6452 water not heating
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 29, 2010 | Zanussi Dishwashers
How to install zanussi dx6452 heating element
disconnect from electric and water supply. remove drain screen from inside dw , mopp up residual water. remove front feet and plinth cover, and right hand side panel. with machine on its back remove rear foot adjustment shaft.and base cover. disconnect wiring to tube enclosed heater. remove hoses very long nosed pliers help to get clips off/on. extract to righthand side. not much space to work here assemble in reverse. good luck
Jul 21, 2010 | Zanussi Dishwashers
I have a zanussi zce7680 and the fan works but no heat any ideas
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Zanussi ZCE7680 Electric Kitchen Range
Our Zanuassi zob 1060 oven has stopped heating on all elements. Fan and display still works, eventually an error code E80 appears
Check that the timer is set for Manual/not auto...Next if no joy could be heating element, check with multimeter should read about 2 ohms if okay...
Apr 12, 2010 | Zanussi ZWF1440 Front Load Washer
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Dishwashers Logo
181 people viewed this question
Top Dishwashers Experts
Owen Barnes
