Question about Polaroid FLM-323B Television
No signal get no signal on screen. when i connect back to old tv works fine.
  • Olive923 Mar 30, 2008
    connected the power of the tv to the cable remote, now when I turn the cable on, the tv light turns blue, but there is no picture?
  • ccvalbaybee Apr 09, 2008
    Connected cable to Tv. no signal, called Polaroid went through all the steps, which we already tried. Tried to plug in t.v. to other cable line in house, same problem, all other t.v. works fine.
  • 4 Answers
Fixed one today with similar problems. Power supply board issue. Just a few bucks for parts.
Posted on Jun 04, 2008
  • 3 Answers
Give me more detail, i might of had the same problem as you.
Posted on Mar 25, 2008
The signal loss along with channel 4 is the only thing on TV screen. The other TV is fine. Checked connections all seem to be fine.
Are you connecting TV receiver box (example: DirecTV receiver); or what is the source? What TV are you using - a new flatscreen / HD or an old big TV? AN old TV - tube type? You have to get to the right input and sometimes it can be blocked by a Vchip parental wring selection.
Nov 16, 2014 | Televison & Video
Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Jan 11, 2014 | Televison & Video
I inherited a Sharp LCD 32" flat screen TV that's only about 2.5 years old. It worked fine at its previous location. Upon bringing it to my house, I've tried disconnecting the cable from my TV &...
Try going into your setup menu. Look for a setting for "Cable/Air". Try switching it to Cable and then doing a channel search. If you are using a cable box try setting channel to 3 on tv. Those are the two easiest things I can think of off the top of my head without seeing it.
Jul 09, 2010 | Sharp LC-32SB21U 32 in. LCD TV
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
STB won't work, TV works well without it
Blue screen means tv is not getting signal. Either stb is not working or you are not connected to it correctly; check the cabling.
Feb 05, 2018 | JVC AV-27S776 TV
Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
S-video connection of a DVD to 40" sony bravia
I need to know if you see a no signal message on tv or just a blank screen. Please provide this information so that I can assist you.
Thanks,
Sai.
Feb 01, 2009 | Sharp DVMX1U DVD Player
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Polaroid FLM-323B Television Logo
73 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
