Question about Toshiba 52HM95 52" HDTV Projection Television
No picture sound is good
I watch the t.v for about 1 night . the next morning i turned it on and i had sound but no picture. i check the blub the blub seem to be good. so want else would i have to check for the problem. can you help?
  • cliffgee Feb 22, 2008
    thanks for the help
  • wfoor44 Mar 07, 2008
    i have a toshiba 62" DLP. i turn it on and the green light just flashes and i have sound. the bulb is good. what is the deal?
The lamp my apper good by visuly looking at it but still could be bad. also this tv has a ballast that powers the lamp. and that could be bad...
Posted on Feb 20, 2008
My philips 32pf 5531d/10 has no picture by sound?
Check for the Ac power cord, the fuses and the power supply Module.
Nov 04, 2012 | Televison & Video
NO Picture
hello,
First check if the power cable of the television is firmly connected to the main socket, if otherwise open the back cover of the television to check for blown fuses, and otherwise .
well this is common on your model and could be a few different things. one is the video circuit and a cost would range around 100.00. the other is a weak picture tube this would cost more than the TV . sometimes when it is the tube we can adjust it but it does not always last long. sounds to me it would be better to invest into a newer TV in this case.
Hope this help....
good luck :)
let me know if you need more info??
Jun 02, 2010 | Hitachi 50VG825 50 in. LCD HDTV
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Apr 27, 2009 | Hitachi Televison & Video
No picture ... thumping sound from speaker1
Check the horizontal output transistor. If that is good you will most likely need a new flyback
May 26, 2008 | RCA P46810LV 46" Rear Projection...
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Power
if the tv set have no sound no picture, they call it dead set your tv need a repairman technician to trace your tv what was part was damage. but if your tv has standby mode mybe you entered the timer code.
Aug 20, 2007 | JVC AV-32D305 32" TV
PLTV-32 GOOD PICTURE, Static Sound
If it is under warranty, you would be better off the return it for an exchange as the main board will need to be replaced. this board is not cheap. Good Luck
Mar 21, 2007 | Protron PLTV-32 Television
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Toshiba 52HM95 52" HDTV Projection Television Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
