Question about HP LaserJet 4 plus Printer
My 5 in one laserjet 3050 prints black line on left side of paper when copy feed of paper is performed, if you print document straight from computer it does fine. ?? any posible solutions? We have tried new toner cart. but it was a refurb not man.
    President:
  • 1,185 Answers
You have dirt on the scan bar head so it produces an image on the paper.
When you print directly from the PC it does not use the scan bar
Take the glass off and clean the scan head
Posted on Feb 07, 2010
  • 150 Answers
Clean the glass
Posted on Feb 05, 2010
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
3050
when we copy or scan we get lines at both side throught
the paper
Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Troubles with copying
Pull the Top Loading Document Feeder up towards you from the back, to open and view the clear strip (perspex). I also had this problem, and fixed it by cleaning this strip. for future reference don't use whiteout on papers your going to fax/copy ;)
Feb 07, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 paper jam
The rollers may be worn so it is not getting picked up evenly. Also, be sure that your paper tray in aligned properlyand guides are keeping the paper straight. If both of these seems to be good then there may be something in the paper path.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Jan 08, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 4 plus Printer Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
