Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My cruzer micro gets hot and wont light up
My cruzer micro gets hot and wont light up anymore also, it asks me to reformat
4 Suggested Answers
  • 53 Answers
SOURCE: I have a Scandisk Cruzer Micro 2.0 GB that when
sorry but you have suffer a electric surge that resulted for your drive to not to work, and im sorry it's busted... try formatting it but if this doesn't work the it is already gone south....
Posted on Jun 23, 2009
Geekman
  • 32281 Answers
SOURCE: PC is not detecting my Cruzer micro pendrive but
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Nov 06, 2009
SOURCE: I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Posted on May 08, 2010
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB plugged it, light on, but shows an empty file in windows with capacity of 0bytes Also shows a CD drive (the one that U3 runs) which says nothing is in disk drive.
It is likely an issue with the filesystem. The FAT filesystem gets easily corrupted. If that's the case, reformatting it with FAT32 should help. But remember - reformatting erases all the data, so don't do it if you have anything important on the drive!
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Oct 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer won't recognize my cruzer micro 8gb stick. I don't want to reformat, because I have at least 1000 pictures, plus Quickbooks, Legacy and other data on it. Anyone have any ideas?
some older pcs wont recognise sticks and sd cards larger than 4gb. it will probabaly be down to the version and service pack of windows you are using.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
U3 smart 4GB wont work
hey there, Sounds like you just need to reformat the drive to get everything working. If you click on the following link it will take yyou to a site to download recuva. Go ahead and install it and it should be able to pull the files off of your drive as long as your pc is recognizing it. Once you get them off and verify they are all ok, go ahead and reformat. Let me know if there is anything else I can help you with.
seth
recuva
Jul 29, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer micro 4 gb
try to connect it firs to other computer, if other computer can detect it,format it..if not,that means your sandisk wont be usable anymore.
Oct 16, 2008 | SanDisk Cruzer Micro MP3 Player
Usb
Try to back up all important data and reformat the drive.
Apr 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Data recovery
Because it formats the device, if the restore option didn't work then it sounds like bad news. I would recommend searching your pc for the images just in case the U3 uninstaller cached them somewhere during the process.
Feb 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Micro Cruzer reduced from 2.0 GB to 1.0 MB when reformated
Make sure you check to see if the File System is FAT32 instead of FAT or NTFS, this way you can have your 2GB back.
Try reformatting using FAT32.
Dec 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
304 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
