Question about Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator
Frigidaire over range microwave oven: Door hanging from only top hinge when opening/closing. Came off bottom hinge and can't figure out how to access to repair.
Take 3 screws out to take bottom off then you can reach the hinge -I put a screw with a nut in the hole there above the hinge,
fixed mine
Posted on Aug 19, 2010
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
We need to change the door on our microwave. We have the new door, but can't find anything in the manual about removing the old door. It is a Frigidaire Gallery series above range microwave. Any...
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Sep 05, 2009 | Kenmore 62622 Microwave Oven
I have a 1.5 over the range fridgidaire microwave...it seems the door hangs a little low because in order for it to work you have to put your thumb on the bottom of the door to raise it up a little and...
Does it seem to hang low or does it actually hang low? Readjust it. There is a switch that may hang high when the door closes. You just have look at what does what and what ain' doing what it is supposed to. first.
May 04, 2009 | Frigidaire Over-the-Range Microwave
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator Logo
226 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
