Question about Panasonic Lumix DMC-FX01 Digital Camera
Lens comes out when switched on but then will not move in or out using button on the top, also it will not actually take picture. Have not used camera for 12 months so wondering if it has just seized and if there is any easy way to clean inside?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 04, 2010
Testimonial: "Thank you very much for your advice. The answer was clear and concise with the remedies listed in order of safety for the cameras wellbeing "
The picture is to wide, been through settings and cannot bring picture in to fit screen
Check what lens you are using sometimes you need a wide angle to do some photos, camera will not select lens for you ,you must do that yourself
Mar 07, 2015 | Cameras
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
THE LCD PICTURE IS CLEAR AND WHEN I PUSH THE BUTTON TO SHOT, IT STARTED TO BLURD THE PICTURE AT LCD AND PICTURE RESULT ALSO IS BLURD.
Hi chicbenzon_1 ,
The LCD picture is clear indicates that the lens is clear enough to capture the image, if there would be any disturbance on the lens you would come to know on the LCD itself.
When you push the button to shoot , it could be that you are pressing the button just half way which is a function used to focus on the object before full press of the button or actual shot of the image.
I would recommend you to half press the button till you focus on your image and then when your hands are steady and there is no shake on the camera , go ahead and press the button full which would result in the image being taken.
Hope this helps ...:)
May 11, 2011 | Olympus FE-320 Digital Camera
Double sided printing - 1st side, no problem 2nd side - instructions said to push down orange button. Button does not release - both green and red lights are blinking - does not print. I have gone...
I have the same problem as the original poster in that the orange button goes down when pressed but then slips just a little to the side and won't come back up.
I've made it come up by pounding on the case next to the button with my fist, by jiggling the button with the eraser end of a pencil (usually resulting in it ruining the printing of the booklet I am trying to print by printing a test page), by grasping the side of the top casing near the button and trying to flex it, and by using a pocket knife to try to make the button's hole bigger in the casing. It finally got so bad that nothing I would do would make the button work.
So I took the top off and found out that the "orange button" has an offset part that is what actually contacts the switch, and that the orange plastic part is mounted in a clear plastic piece which also acts as the lens portion for the red and green lights. The clear plastic piece is attached to the cover with two screws.
Over time, the clear plastic piece had broken in half, allowing the part holding the orange button to swivel. This initially was what would cause the button to get hung up under the hole and not able to come back up, and eventually through all my efforts to make it come up it moved the portion of the orange button that contacts the actual switch far enough that it no longer would make contact.
Three possible fixes: 1. Order a new clear plastic piece from Samsung. 2. Glue the clear plastic piece back together and hope it holds. 3. Go the ugly but sure route of removing the broken part of the clear plastic piece along with the orange button and spring, and cut the top open between the button hole and the edge so that the actual switch can be reached.
I chose number 3: This will void your warranty, but mine was way out of warranty anyway.
First, I turned the printer off and unplugged the power cord.
I took off the top, by opening the front panel of the printer where the toner cartridge is installed, then removing the two screws that hold the front of the top down. Then it was a matter of daring to break the plastic of the top panel in freeing the plastic tabs so that the panel could be removed.
I found that by lifting the front until the side tabs gave way and then removing the hinged cover where the paper comes out, I was able to finagle the top off without damaging anything. It probably would be easier to remove by taking the screws out of the black rear cover and so forth, but this worked.
Next, with the cover removed and turned upside down, I removed the screw holding the broken portion of the clear plastic piece and removed it along with the orange button and spring. I left the other half in place so that it would transmit the light properly for the red and green lights.
Then, taking my trusty Leatherman tool, I used the saw blade to open up the area between the button hole and the outside edge of the top. I used the Leatherman's file to smooth off the rough edges.
Next, I reassembled the printer (this was probably the hardest part - and at this point is when I realized that taking the back off would maybe make things easier, but if you aren't afraid to torque the plastic a bit it will all snap back into place), plugged it back in and fired it up.
I printed a test booklet. First side printed normally, the red light came on as it should. I removed the paper and reinserted it, then used a pencil to reach in and press the switch. Success! The second side then printed!
The problem is solved! The printer looks a bit worse for wear, with a big hole where the button used to be, but that is of little matter to me.
Because there may be a danger of electric shock, I would advise that if you choose this repair method you use a pencil or other stylus to reach in and press the button on the switch instead of using your finger.
You may find that it will take a bit more pressure than you think it will to actually trigger the switch.
Dec 06, 2010 | Samsung ML-2510 Laser Printer
Having opened the top pannel to clean lens, my Laserjet 5000N came up with this error message. "printer error 52.0"
52 is a scanner error, the scanner here is actually a rotating mirror assembly that 'scans' the laser right to left. (as the paper moves top to bottom)
Make sure you did not smudge the lens or move it too far in any direction. Gently use a clean q-tip or equivalent to 'reclean' the lens.
Then, power down, count to 10, power up.
Same error?
Power down. Find green checkmark button, power up, when memory starts to count, press and hold green checkmark button until ready, data, and attention lights all flash. Release Green checkmark button, display should say "Select Language".
Press Down arrow once, display should say "Cold Reset".
Press select and wait for a reboot to complete.
If you still have the error, then you have a physical problem and will need a repair tech to fix it.
Aug 31, 2010 | Computers & Internet
Blinking circle when i try to take a picture
The camera is cannot confirm focus, so it locks up. Try changing the button on the lens to M. Manually focus the lens on something and take a picture. Move the button back to A (autofocus). It should work ok.
If not, try moving the switch back and forth several times to clean any corrosion.
Try another lens on it to determine if its the camera or the lens.
Lightspiritphotography.com
Nov 21, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
The zoom button isn't working and therefore when looking through the lens everything is blurry
Follow the instructions below to check and test the focusing of the camcorder.
Manual Focus
✤ In the following situations, you may obtain better
results by adjusting the focus manually.
a. A picture containing several objects, some close to the
Camcorder, others further away.
b. A person enveloped in fog or surrounded by snow.
c. Very shiny or glossy surfaces like a car.
d. People or objects moving constantly or quickly
like an athlete or a crowd.
1. Set the [Power] switch to [CAMERA].
2. Set the [Mode] switch to [TAPE] or [CARD].
(SC-D375(H)/D975 only)
3. Press the [Q.MENU] button.
 Quick menu list will appear.
4. Press the up/down arrow button to select <Focus>, then
press the [OK] button.
5. Press the up/down arrow button to select <Manual>, then
6. To exit, press the [Q.MENU] button.
 The [MF] icon and the [MF/AF] status bar will be
displayed on the LCD screen.
7. Press the up/down arrow button to adjust the focus.
[ Note ]
Manual Focus is not available in the EASY.Q mode.
Make sure the lens is clean--use a soft cloth and don't press hard when wiping--use a circular motion starting from the center of the lens and working to the outside--that way, you wont grind dirt into the glass. If the lens is dirty enough, the camera will actually try to focus on the smudge or finger prints on the lens! Look into the lens and use the zoom button--do the interior lenses move forward and backward? The zoom button could be damaged(liquid or impact), or the lens could be jammed due to impact or liquid( I just fixed my sister-in-law's unit--had cola in it and sugar acts like super glue when dry.)(Lenses jam due to excess heat, too) NEVER leave a camcorder in a hot car. The grease used to enable the parts to move freely and smoothly can flow to sensitive areas and stick like glue.
If the focusing is indeed stuck, the unit must be repaired at a reputable facility. Don't send it in through a retail store unless under warranty.--Hope I was of help.---Rick
Oct 02, 2009 | Samsung SC-D372 Camcorder
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Help please
Is the lens moving/focusing?
If you switch to manual focus, can you make a shot?
Is it possible that "remote control" mode is selected (the button on top, right, in front of AF button) - in this mode the camera focuses but waits for the remote to shoot - just press the mode button until the LCD shows [S]
Dec 10, 2007 | Nikon D80 Digital Camera with 18-135mm...
Lens not moving
The lens mechanism is shot. Depending on the age and possible cause of the condition- has it been dropped? I would think replacing the camera is a better option than trying to get it repaired -which I think is not a likely option
Jul 25, 2007 | Toshiba PDR-3320 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
337 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
