FL code on a Calypso Whirlpool washer
What's the most common issue when this code appears (FL) on the whirlpool calypso washing machine?
  • Washing Mach... Master
  • 8,220 Answers
FL= Flood Condition
FL flashes if any overfill condition
occurs. This condition occurs when
excessive water in the tub causes the
overfill switch to trip. The control must
realize that the trio was due to an
overfill condition instead of a suds lock
condition in order for FL to be displayed.
With an overfill condition, the beeper
repeats a warning every 10 seconds with no
time out. The pump is cycled in drain mode
for 30 secondson 30 seconds off untill the
overfill switch resets or power is
discontinued to the unit.
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves
stuck on, Sediment in water level pressure
tube.
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 04, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Nov 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Getting ''FL'' error code w/Whirlpool Calypso
you can try unplugging the washer and letting it reset the system. thenplug it inand press the spin/drain button. if it still gives you the flood condition chances are the pump is faulty and needs to be replaced. it may be covered under whirlpools warranty for the law suite against the washer. otherwise you can get the pump off ebay for cheep and install it yourself. its just a little messy so if you do it yourself make sure you have a shop vac around to **** up the excesswater.
Nov 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washing machine
fl is short for flood..possible something has pump impeller blocked ..if you hear a slight hum that is most likely what it is although on 1st generation the pump had a splined shaft that was bad about stripping only solution there was complete change out update version has a pump with 4 screws in bottom they can be removed to clean impeller area remove as much water as possible.. shop vac helps.. lean washer back and remove bottom to acess pump
Jul 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Fl display on washer
possible but may be a pump issue as well ckd pump first..pump comes off motor if it has never been changed before ..if it has been changed new style has 4 torx screws remove as much water as possible tilt machine back remove screws and look for something in pump old style pump had plastic splines that would strip slim chnce but could be issue with water level switches or ever present control board commuication problems
May 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
182 people viewed this question
Top Washing Machines Experts
