Question about Microsoft Windows Server Standard 2003 for PC
I get the STOP: C0000218 {Registry File Failure} The registry cannot load the hive (file):System RootSystem32ConfigSECURITY or its log or alternate. It is corrupt, absent, or not writable..On my windows xp and I do not have a back up disk because it is in my d driver can anyone help?
    Problem Solver:
  • 10 Answers
This is one of the main reasons I prefer to do a clean installation from CD rather than simply doing a system restore. There's less chance for something to go wrong with a clean installation. Unfortunately, many computer manufacturers no longer provide a complete CD, but you still may be able to completely wipe your drive rather than using the restore option. The Stop: c0000218 error is typically associated with one of several things, depending on how far through the recovery process you made it before encountering the error.
The first possibility is simply corruption in the Windows Registry. A second option is a component of your system hardware is not compatible with Windows XP or your hard drive has some kind of issue. Since you are re-installing Windows XP using System Restore, it seems unlikely your system hardware is incompatible, although I won't rule out the possibility entirely. The third possibility, a damaged hard drive, is possible even if Windows appeared to run smoothly prior to your reinstallation. Before throwing in the towel, we'll take a closer look at each possibility
Assuming the Windows Registry is simply corrupt, the first thing to attempt is a recovery via the Automatic System Recovery for your particular installation. Since you are attempting to do a system restore, it's possible you already tried this and had it fail. If this is not the case, follow the detailed directions presented in Microsoft Knowledge Base article 307545.
If you attempted your system restore using the OEM provided restore partition or CD and received this error, make sure you don't have any hardware components connected which weren't part of the initial build of your computer. System restore disks look for specific hardware components. If the original components are missing it occasionally introduces errors in the restore process.
A third possibility is the hard drive is damaged in some way. Many disks have bad sectors and you won't know about them until you attempt to write over the sectors during a specific operation. If you can boot from your install CD, you will be presented with the option to Repair or Recover the Windows XP installation. Pressing R launches the Microsoft Recovery Console which then asks for the Administrator password. After entering the password, run chkdsk to check the drive for errors by typing chkdsk /r at the command line. If chkdsk finds errors, you may need to use chkdsk /f to repair the errors before proceeding.
Since you are attempting to revert your Windows installation back to baseline, the best option remains doing a completely fresh install because it will avoid any potential corruptions already existing in your current installation by installing a fresh copy of Windows instead of reusing existing core components that may now be corrupt.
Have this as a guide when you perform system restore in recovery console..http://www.myfixes.com/articles/system..
Hope this will help..
Posted on Feb 05, 2010
2 Suggested Answers
  • 13433 Answers
SOURCE: STOP: C0000218 {Registry File Failure} The registry cannot load the hive (file):\System Root\System32\Config\SECURITY or its log or alternate. It is corrupt, absent, or not writable.
to fix the problem, you need the Installation cd, put it in, start the setup, and enter repair console when the first blue menu comes up.
In repair console, your going to have to copy the windows\repair directory to system32\config
to fix the problem.
After the files have been copyed, Well maybe might be better if you only copy the SECURITY file. so no login details get changed.
Then restart the pc and see if it worked. If not your going to have to perform a repair installation from the xp cd.
If you need more asistance, let me know. Good luck.
Posted on Mar 31, 2008
My Gateway file c0000218 registry failure the registry cannot load the hive /SystemRoot/System/32/Config/System or its log or alternate is. It is corrupt, absent or, not writable.
it sounds like you have a bad sector on the part of the hard drive containing this file. you need to let chkdsk complete the scan as it may be able to recover the corrupt file and isolate the bad sector so its not used again.
if this works backup the system as your hard drive may be failing.
Mar 09, 2012 | Gateway MT6821 Notebook
Blue crash screen
http://support.microsoft.com/kb/830084
This page is Microsoft's answer to your question.I sure hope this helps?
Mar 10, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
Will not boot up past the message I describe below
You might reload your Operating System to correct this. Insert your Recovery disk into your drive, choose DVD as Boot Option, recover your OS.
Nov 22, 2009 | Sony VAIO VGN-FJ270/B Notebook
Blue screen: Stop: c0000218 {Registry File
Hi.
You would have to have the operating system repaired or completely re-installed.
Please rate me. Thank You.
Apr 16, 2009 | Acer Aspire 5315 Notebook
to fix the problem.
Mar 29, 2008 | Microsoft Windows Server Standard 2003 for...
Registry file failure
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Nov 12, 2006 | Dell Inspiron 600M Notebook
Microsoft Windows Server Standard 2003 for PC Logo
308 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
