Question about Palm Tungsten E2 Handheld
Calibrating Touchscreen I cannot exit the calibration mode. It just keeps going over and over from one bullseye to the next.
  • Squint92543 Feb 24, 2008
    A hard reset solved this problem until finally after two months my screen froze and even a hard reset won't cure the problem. My PDA was less than 90 days old when the touchscreen started needing recalibration frequently. A simple reset solved the problem early on, but then it became necessary to use a hard reset. Now nothing works. It is dead: The unit has been well charged and even with the charger plugged in all I get is the Preferences\ date & Time screen. When I touch "Done" Nothing Happens. When I do a hard or soft reset it returns to the same frozen screen
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
Apr 12, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
The touchscreen of my sons vtech storio wont work, even after calibration? he only got it yesterday for christmas!
connect your toy to the Learning Lodge. Go to Calibrate Touch Screen option....make sure that you are also using fresh batteries.
Dec 26, 2013 | Vtech V.Reader Interactive Reading System
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
I have a samsung reality and im having problems getting it to calibrate right. its the bottom part of my touchscreen that i have trouble calibrating.
hi sdi black841 take the battery out of the phone then put it back in . Next go to your settings and go to calibrations on your phone.this should help you
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Mar 09, 2011 | Samsung Cell Phones
I need calibration instructions
This unit is self calibrating. There is no method for manually calibrating this tool. Just hold the sensor flat against the wall and depress the button. After a few seconds the unit is calibrated and you can begin sliding it smoothly across your wall to detect studs and wires.
Dec 29, 2010 | Black & Decker BLACK DECKER BDL153S Stud ...
Calibrating compass
Yes you can.What you have to do is press the mode button on the driver info center(DIC).Press and hold the set button for 3 seconds.The DIC will display the zone.This is what part of the country you live in.What state your in.I don`t know what Zone your in so I don`t know if it is in the correct zone or not.They go from i-15.This will determine how accurate your compass will be.If you press set it will change the zones.If it is the correct zone then press the mode set button til the DIC displays calibrate compass.Press set and the DIC will tell you to drive in circles.Find a large empty parking lot to do this.I just crank the steering wheel and keep going in circles.The DIC will say calibrating.When the compass shows direction and temperature it is done calibrating and you can stop driving in circles.Hope this helps.Good luck.If you need to know what Zone your in Just post back with the state you live in and I can tell you the zone.
Mar 29, 2010 | 2002 Buick Rendezvous
Can not seem to set my altimeter on the ws4 timex i have tryed do this but it is giving me the wrong hight ? and know one in the shops can figger this out to????? what am i doing wrong iv tryed to folow...
Setting and Calibrating Your Altitude
1. Press MODE until CAL is shown.
2. Hold SET to begin the calibration.
3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather).
4. Press MODE (NEXT) to begin the setting process.
5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values.
6. Set the value to your current elevation.
7. Press MODE (NEXT) to advance to the next setting option.
8. Press SET (DONE) to finish.
9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
Jan 05, 2010 | Timex Watches
The buttons on my lcd screen does not work anymore. I tried calibrating it, but it just stays in calibrating mode as if it is not calibrating. this is for the DcR hc21
hi, if your lcd's touchscreen is not working only,then not to worry about just replace the lcd flap and its done,its very easyly avilable and easy to replace
Aug 25, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Calibrating the stick and screen
Go into system and choose calibration.
Dec 17, 2008 | Palm Tungsten E Handheld
Palm Tungsten E2 Handheld Logo
144 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
