Question about Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look
I have a new side by side. The freezer door, side panel (2 inches with molding) has moisture buildup that is running down the door. What is causing this, and how do you fix it? I have had two technicians out, and neither have resolved the problem. It is one month old.
  • 291 Answers
Air Leak or insufficient insulation in the door. I am sure the technicians have checked for an air leak by now(usually from a door gasket not sealing correctly),so I suspect that your door wasn't fully insulated at the factory. They will have to replace the door to repair the problem. When they build the doors, they put it all together, and then shoot a liquid insulation into it that expands and fills all the empty spaces. Sometimes it leaves an empty space, which then causes moisture or ice build up on the door. Good Luck, Appliance Specialists.
Posted on Feb 04, 2010
I keep getting an ice buildup in my freezer causing my fridge not to cold whats causing this i have manually defrost it many times an still the ice keeps coming back
Every time you open the door, humid air enters and the moisture freezes. Try not to keep the door open for very long. Air conditioning can help dry out the air too. Then dryer air has less moisture and this will slow down the ice buildup problem.
Dec 05, 2015 | Refrigerators
Gd5sha water under the freezer
This normally occurs when you have a large buildup of ice in the freezer, when it does a defrost there is just too much water for the hat on the compressor to handle. Make sure the door to the freezer & fridge is closing properly & the seal is in good condition & not falling off, moisture in the air causes frost in a freezer. So too many door openings can cause the same problem.
Nov 20, 2013 | Whirlpool Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Moisture buildup on exterior of freezer door
some moisture build up is normal,its called a condensation path,but the whole door may indicate a bad seal or terribly high humidity if it only does this during humid days
Jun 10, 2011 | Kenmore Side by Side Refrigerator
The rubber molding will not keep shut... yesterday I leaned into the ref. area my left arm hit the molding between the freezer and refreg... it was very hot. why?
The door closing problem is usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Door not shutting.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jun 01, 2010 | Amana DRS2660B Side by Side Refrigerator
Hello, we have a whirlpool side by side (estate...between the doors is very hot the compressor is so hot you'd have to have pot holders to remove it. the fan is running fine the fridge and freezer are both...
Check the condensor coils and clean them. The condensor fan may be running slower than normal. It is working hard to move the heat. The area between the doors has a line there purposely to keep it warm so moisture that condenses there when the doors are opened evaporates and doesn't cause mold.
eric
Oct 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Defrosting Problem
Possibly sounds like the heating element on your defroster is burnt out or the drain hole for the defroster is blocked, not allowing the defrosted water to drip underneath the fridge to evaporate, thus causing a buildup of ice. That buildup may be blocking that vent that goes bwtn the freezer and fridge. The heating element is simply checked and/or replaced by removing back panel of freezer. It's about the only thing behind that panel and likes like a row of fins. Google images for a better understanding of what you are looking at. If its a block of ice, you know there is a problem. The element is replaced by simply unplugging it and replacing with a new one. You should also see a small hole at the bottom of the freezer. Try pouring a little water in it and listen to see it its running into the plastic pan that's underneath the fridge (usually visible if you take the grill off). Some models have a hose that kinks up attached to this small hole. Had an Amana freezer that did this on several occasions and cause the whole bottom of the freezer to become a block of ice because the water had no where to go.
Apr 18, 2017 | GE Monogram ZICS360NRRH C... Bottom...
Whirlpool 25.3 Cu. Ft. Frost-Free Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Satina Stainless-Look Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
