Question about Brother MFC-7220 All-In-One Laser Printer
How do I release the toner door on the front of my Borther MFC 7220? It appears to be restricted by a tab on the left side of the door. Never had this problem before.
  • 150 Answers
I think pull evenly and harder. It should open.
Posted on Feb 05, 2010
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
Jul 08, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
How to Reset the page drum count on Brother MFC-8860DN
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Dec 11, 2012 | Brother MFC-8860DN Printer
My brother mfc-7220 printer show"toner
You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
Sep 21, 2011 | Brother MFC-7220 All-In-One Laser Printer
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
Mar 25, 2011 | Brother MFC 7840W Printer
How do you change the cartridge? i am having difficulty removing it.
hi,
you open the front door and pull out the toner cartridge/drum. when you open the door there is a little handle on the left that unrestricts the cartridge from coming out. once its out, you push a button, (there may be 2) on the right side and possibly left, you push them down to separate the toner from the drum
thanks
Sep 01, 2010 | Brother HL-2040 Laser Printer
Brother mfc 9700 need to change toner cartridge but drum wont come off, how do i get this off safely and back on again?
If you open the door and the toner doesn't release, there may be a broken gear on the left side that releases it. The black lever on the left side of the door disengages the toner and when that doesn't pull freely the gear inside is broken and a shop needs to replace for you. If just the toner, you press the blue lever and lift the toner off of the drum.
Jan 19, 2010 | Brother MFC 9700 All-In-One Laser Printer
Need new drum for brother mfc-7220 all in one. Not even 1 year old. Is there something I can repair or fix instead of replacing the drum for about $100+ ?
If the print quality is still good, just reset the drum counter. Open the front door, press OPTION, press 1, close front door.
Oct 05, 2009 | Brother MFC-7220 All-In-One Laser Printer
I have a Brother MFC 7220 printer. When printing, there is an almost indelible, yet noticeable line down the left-center of the page. How do I get rid of it? In short, how do I clean the Brother MFC...
This could be the result of several problems. The quickest, cheapest, and easiest thing to try is to clean the "corona wire". This is done by removing the drum/toner unit. On the drum unit (the big grey cradle) is a blue tab with an arrow on it. Slide this back and forth twice, being sure that the two arrows line up when you are done. Put it back in the machine, and make a copy or print from your computer to test the quality. If this does not solve the problem, you may need a new drum (every 12,000 pages) or a new toner cartridge (about every 2,500 pages).
Apr 09, 2009 | Brother MFC-7220 All-In-One Laser Printer
Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
May 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
