I have Kenmore Elite HE3 Front Load Model 110.5862400. The rubber gasket/bellow got wadded up with clothes and popped out along with the clamp. How do I put back together. There is no damage but I don't see where the clamp goes. Thanks
  • 5,911 Answers
The following link explains the steps required to install a door bellow on a front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Inspect the bellow and the front and rear clamps to ensure they are not damaged. If the bellow has any rips or tears, it must be replaced or it will leak.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer can contribute to items getting caught in the bellow and causing premature wear. Follow the manufacturer's recommendations for proper loading.
Posted on Feb 04, 2010
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore elite He3 leaking water into tub
Outstanding diagnosis. You are correct to assume a water inlet problem and, "yes", this can be a common problem. If you live in area that has hard water, or if you use well water, sediment, rust and calcified deposits can clog the small diaphragms inside the valve causing them not to close properly and leak by. You can attempt to clean the valve by removing it and submerging it in a 50/50 solution of distilled vinegar and hot water for about 30 minutes, Sometimes this can dissolve any clogs and restore the valve to full operate. However, if this does not work, you will need to replace the valve.
The following link explains the steps required to replace the valve if you need directions:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I have included web resources to search for replacement parts.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
May 29, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Billow ring and front clamp
The following link explains how to access and replace the door bellow on a Kenmore Elite front loader:
Step 12 refers to how to reinstall the front bellow clamp (wire hoop with a spring).
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. The part number for a replacement bellow for the model you listed this question under is 8182119.
If you have questions about this repair, please post back and let me know. I hope you find this information helpful.
NOTE: The delivery time for parts depends on the postage you are willing to pay. Each site varies, so you will need to review their shipping costs. Some ship in as little as one day.
May 06, 2010 | Kenmore Elite 45986 Front Load Washer
I have a 110.47532600 washer and the door gasket is leaking (ripped) Can I buy a replacemnet
You certainly can. Searspartsdirect.com carries the part for about $64. Just type in your model number and look under the "Door and Latch Parts" section for item 1. You may also consider items 2 and 8. Item 2 is the rear bellow clamp. Item 8 is the front bellow clamp. Order only if your existing clamps are damaged or broken. If you need instructions on how to replace the bellow, the following link explains:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions, please let me know. I hope you find this information helpful.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Rubber boot and spring need put back in
The rubber boot presses on the rim, and the spring clamp fits in the groove behind it. Don't overtighten.
--W/D--
I have a Kenmore elite front load washer. The
The rubber liner (called a "bellow") can be purchased for less than $100. If you wish to install yourself, the following link explains:
If the bellow isn't damaged, you can still use the link provided to simply re-install it. If the outer bellow clamp (wire hoop with a spring) is damaged it can also be purchased for about $20 or less. Searspartsdirect.com or appliancepartspros.com offer the best prices with exploded view diagrams of your washer. Just use your model number (located along the door opening) for your search criteria.
So, the choice is yours. Spend about $100 (if required) and repair this yourself. Or, spend $$$ for a new washer. I own a model like yours and I know it wasn't cheap. If the only think wrong with the washer is the door bellow, I think this just may be worth the time and effort to repair.
Jul 12, 2009 | Washing Machines
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
