Question about Ricoh Aficio 2020D Copier
Showing an error where there is no paper jam. Model Aficio 2020D. It's showing an "R" error in the paper dispenser but there is no jam there and machine won't clear after opening it up & closing it numerous times.
  • 67 Answers
Cleane sensors in paper path
Posted on Aug 26, 2010
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Aug 14, 2014 | Ricoh Aficio 2020 All-In-One Laser Printer
Ricoh aficio 1032
Is the paper jamming inside the copier or a error code showing??? Odds are that there is a problem with the fuser unit, mainly the pressure of one or both sides of the lower pressure roller. You may need to get a service person to repair you copier...
May 20, 2013 | Office Equipment & Supplies
It tells me to load paper in tray 2 but the papers full
first check that sensor feel with sensor or left motor is not deafective paper sensor with stick exmine that is touch paper
Apr 01, 2011 | Ricoh Aficio 2020D Copier
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
I have a aficio 200 and it is showing a fault misfeed at a and i have removed the paper but it seems to be stuck at that point
If after clearing the jam; the machine warms up, trys to feed again, and jams. There is something causing it to jam. This could be a feed roller, clutch, or sensor. If the jam never clears; you likely have a small chunk of paper sitting on a sensor, or a faulty sensor. Get a flashlight and take a good look into the "a" section, its a tight area but also short, so finding the paper shouldn't be too hard if there is some in there. Getting it out may require a long screw driver or canned air.
Nov 05, 2009 | Ricoh Aficio 250 Copier
Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic 91009d0.jpg
Apr 15, 2009 | Ricoh Aficio 1013F Copier
I have a Ricoh Aficio 1224c, the illumination light indicating that there is a problem with the paper feed is remaining on even though there is no obstructions, this has been checked and cleaned carefully....
There is likely a very small piece of paper, that may be very difficult, or even impossible to see, without some dis-assembly, or there has been an actuator dislodged in the jam removal process. Either way, you'll probably need a tech on this oe
Mar 06, 2009 | Ricoh Office Equipment & Supplies
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
211 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
