Question about Garden
Oil pump is not oiling chain - Garden
    President:
  • 2,220 Answers
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You provide no make, model or serial number. Post back with these and I can provide considerably more help. HTH
Lou
Posted on Feb 04, 2010
Stihl chain saw 024 AV , chain does not get oil
run it with the bar off and see if it pumps oil. I have drained oil tank and cleaned with gas(no run) then replaced with lite oil , run no chain and got them going ,or then gingerly run wire into oil hole and got them going, otherwise its tear apart time. If oil does come out, then clean your bar and your cover and use bar chain oil.
Mar 01, 2015 | Stihl 024av
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
Apr 25, 2012 | 2003 Ford Expedition
Where is the oil pump on 01 ford explorer sport trac and how hard is it to replace it
OIL PUMP IN THE OIL PAN.YOU HAVE TO REMOVE OIL PAN TO REPLACE OIL PUMP.IF YOU HAVE 4.6L ENGINE YOU HAVE TO REMOVE FRONT TIMING CHAIN COVER AND TIMING CHAIN.REMOVE OIL PAN.REMOVE THREE BOLTS AND THE OIL PUMP SCREEN COVER TUBE AND REMOVE OIL PUMP.YOU NEED TO SUBMERGE NEW OIL PUMP IN CLEAN ENGINE OIL TO PRIME IT.
Jul 21, 2011 | 2001 Ford Explorer Sport Trac
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
How to replace oil pump on 2004 bmw 545i
M62 ENGINE TURN OFF RADIO FIRST. YOU NEED TO INSTALL A MEMORY SAVER BEFORE DISCONNECTING NEGATIVE BATTERY CABLE. TO KEEP FROM LOSING PCM MEMORY. TO REMOVE OIL PUMP.YOU NEED TO LOWER OIL PAN.REMOVE THE LEFT AND RIGHT ENGINE MOUNTS AT THE BOTTOM.REMOVE POWER STEERING PUMP AT THE HOLDER.REMOVE OIL PIPES AT THE POWER STEERING PUMP ALSO ON AUTOMATIC TRANSMISSION, REMOVE BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN.REMOVE THE MOUNTING BOLT ON THE SPROCKET FOR THE OIL PUMP AND REMOVE THE SPROCKET ALONG WITH THE CHAIN,REMOVE 3 OIL PUMP MOUNTING BOLTS AND REMOVE THE OIL PUMP.REMOVE THE OIL PIPES OUT OF THE CRANKCASE. BEFORE INSTALLING NEW OIL PUMP, CHECK SEALS ON THE OIL PIPES AND REPLACE IF IT NECESSARY.LUBRICATE THE SEALS WITH OIL AND THE OIL PIPES.CHECK THE SEAL IN THE OIL PUMP AND REPLACE IF NECESSARY, SCREW THE HEXAGON ADAPTER BACK INTO THE OIL PUMP UNTIL IT STOPS.INSTALL OIL PUMP AND 2 RIGHT SIDE OIL PUMP MOUNTING BOLTS .TORQUE BOLTS 14 - 17 FT LBS. POSITION THE CHAIN ON THE PUMP AND SPROCKET AND INSTALL THE SPROCKET.TORQUE BOLT TO 35 FT LBS VERIFY THAT THE CHAIN IS POSITION CORRECTLY. ADJUST THE CHAIN SAG TO 0.315 - 0.472 INCHES 8 - 12MM BY TURNING THE HEXAGON ADAPTER IN THE OIL PUMP, THEN INSTALL THE LEFT SIDE MOUNTING BOLT. INSTALL OR CONNECT THE FOLLOWING. INSTALL BANJO BOLT FOR THE OIL RETURN PIPE FROM THE OIL FILTER AT THE OIL PAN, INSTALL THE POWER STEERING PUMP AND CONNECT THE OIL LINES IF EQUIPPED.INSTALL LOWER OIL PAN, INSTALL THE ENGINE OIL.INSTALL THE NEGATIVE BATTERY.
Mar 19, 2011 | BMW 545 Cars & Trucks
Do not pump chain oil
Release the chain brake, then remove the bar and chain. Clean the area of the engine where the bar fits to, then start the engine to see whether oil oozes out of the port in the engine. If ok, then clean the bar drive-end small oil passages that run from the large holes out to the chain groove on each edge. If no oil comes out of the port, then internal service is required for the oil pump, oil line, or oil tank filter. Hope this helps!
Dec 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do i change the oil pump in a 2000 dodge intrepid
I'm assuming that you are talking about 2.7L, the check this procedure...
Removal & Installation - 2.7L Engines
  1. Drain the engine oil.
  2. Remove or disconnect the following:
    Crankshaft damper Timing chain cover Timing chain Crankshaft sprocket Oil pan Oil pickup tube and O-RING Oil pump
To install:
Fig. Oil pump mounting bolt locations-2.7L engine
  1. Fill the oil pump rotor cavity with clean engine oil.
  2. Carefully, install the oil pump over the crankshaft and into position.
  3. Install the oil pump mounting bolts and torque to 21 ft. lbs. (28 Nm).
  4. Lubricate the new pickup tube O-ring with clean engine oil and torque the pickup tube mounting bolts to 21 ft. lbs. (28 Nm).
  5. Install or connect the following:
    Oil pan Crankshaft sprocket Timing chain Timing chain cover Crankshaft damper
  6. Fill the engine with clean engine oil.
  7. Start the vehicle, check for leaks and repair if necessary.
Hope helps (remember to rate this).
Oct 02, 2010 | 1999 Dodge Intrepid
How to change oil pump in 4.7
Here you go:
1. Remove the oil pan and pick-up tube.
2. Remove the timing chain cover.
3. Remove timing chain and tensioners.
4. Remove the four (4) bolts, timing chain tensioner and oil pump.
5. Position the oil pump on the crankshaft and install two (2) mounting bolts.
6. Position the primary timing chain tensioner and install the two (2) remaining bolts.
7. Tighten the pump and tensioner retaining bolts to 21 ft lbs in the sequence shown in attached photo.
8. Install the secondary timing chain tensioners, chains, cover, pick-up tube, and oil pan with new gasket.
See the photo below. Hope this helped and best wishes.
Jul 31, 2009 | 2000 Dodge Durango
Oil pump replacement
This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
OIL PUMP
It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
DISASSEMBLY
  1. To remove the relief valve, proceed as follows:
  2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
  1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
  2. Remove oil pump cover screws, and lift off cover.
  3. Remove pump rotors.
  1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
Oil Pump Assembly
  1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
  2. Tighten cover screws to 12 Nm (105 inch lbs.).
  3. Prime oil pump before installation by filling rotor cavity with engine oil.
  4. Install chain case cover. Refer to Timing Chain Cover Installation.
REMOVAL of Timing cover
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove timing chain cover.
REMOVAL Of Oil Pan to gain Access to OIL PUMP
  1. Disconnect negative cable from battery and remove engine oil dipstick.
  2. Raise vehicle on hoist and drain engine oil.
  3. Remove bending brace to transaxle attaching bolt.
  4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
  5. Remove oil pan screws and remove oil pan.
INSTALLATION
  1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
    1. Use a new pan gasket.
    2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
    3. Install dust shield and bending brace to transaxle housing.
    4. Lower vehicle and install oil dipstick.
    5. Connect negative cable to battery.
    6. Fill crankcase with oil to proper level.
Mar 27, 2009 | 1998 Chrysler Town & Country
Garden Logo
305 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
