Question about Whirlpool Calypso GVW9959K Top Load Washer
I keep getting ld error - Whirlpool Calypso GVW9959K Top Load Washer
  • 572 Answers
Long drain error code. replace ur pump with the upgraded version. or unclogg the pump if u have the latest one
Posted on Feb 06, 2010
Sc 241 ricoh mp c300
LD error
LD error continues for 0.5 seconds. (After LD error is detected, a release of LD error is written to the GAVD circuit during monitoring.).
LD unit defective
Dec 03, 2013 | Ricoh Office Equipment & Supplies
Me aparece el codigo de herror sc241
Error de LD
Un error de LD continúa durante 0,5 segundos. (Después de detectarse un error de LD, se escribe una liberación de error de LD en el circuito GAVD durante la monitorización.).
• Unidad LD defectuosa
UNIDAD LD
Dos diodos láser en la unidad LD emiten 2 rayos láser de escaneo principal.
Contar con dos láseres acelera la creación de imágenes. También permite al
motor poligonal funcionar a menor velocidad, lo que reduce el ruido y prolonga la
vida del motor.
Aug 29, 2011 | Ricoh Aficio 1232C Color Copier
Keep getting error code Ld what does this mean
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by the control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for proper pumping.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Post your model number I might have a service manual and a better answer for you.
Jun 22, 2011 | Washing Machines
RICOH AFICIO 1035 I GET AN ERROR CODE SC326 AND PAPER KEEPS GETING JAMED WHERE IT TRIES TO ENTER THE BIG GREEN ROLLER.
SC326 is a laser synch detect error. The jamming is probably just because of the code popping up and the machine shutting down. 9 times out of 10 the cause of an SC326 is toner dust buildup on the laser optics. It is either that or possibly a laser unit (LD Unit) failure. The power to the LD unit flows thru the front door switches and I have seen those go bad and cut or reduce power to the LD unit which will cause the same code. I would get a Ricoh tech out to clean the laser optics. This is especially true if you open the fron door and there is toner dusting around the toner cartridge/DV unit area.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Ricoh Aficio 1035 Copier
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Keep getting error codes such as LD
ld is long drain must be a calypso .. lean washer back remove bottom panel if pump has bottom screws remove and clean pump if not is probably older version ..thet were bad for having stripped drive splines only fix was to replace entire pump
Sep 09, 2008 | Whirlpool Washing Machines
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
LD-14AW1 keeps coming up with OE error code
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Whirlpool Calypso GVW9959K Top Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
