Question about Toro& Electric String Trimmer
Cannot get the cap off of my Toro 8 inch trimmer so I can replace string. Also what size string?
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
SOURCE: Case won't opem
There is a screw underneath the Toro label.   I learned the hard way.
Posted on May 13, 2010
  • 708 Answers
SOURCE: I have a 13
the bumper on the bottom is worn out or the sprin inside it is broken. You should be able to tap it on the ground and string come out.
Posted on Jun 03, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
How do I replace the line in an 11 inch electric toro trimmer I can't turn the part that would come off to put new line in.
All I can do is refer you to the manufacturer's instructions. See page 5 after downloading your user manual. If you can not turn the cap off, then the cap is possibly cross threaded onto the shaft end and/or the threaded end if the driveshaft is stripped. See if the user instructions are of help to you.
http://www.toro.com/en-us/Homeowner/Yard-Tools/Trimmers/Pages/Model.aspx?pid=51347-11-Inch-Electric-Trimmer
Jun 08, 2011 | Toro& Electric String Trimmer
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
What size string does the 910 toro electric trimmer take
12' .050 trimmer line, like that shown at the link below
http://www.google.com/url?sa=t&source=productsearch&cd=1&ved=0CFkQgwgwAA&url=http%3A%2F%2Fwww.amazon.com%2FToro-88075-12-050-Trimmer-Line%2Fdp%2FB0000CBITQ&rct=j&q=910%20toro%20line&tbm=shop&ei=h2HNTd7aCunc0QGq_aDgDQ&usg=AFQjCNF826-xPNQy9XomBFrklrqkvIHGCQ&cad=rja&biw=1280&bih=630
May 13, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
What thread is on a older toro gas straight shaft? it doesn't appear to be 3/8-24 LH but its close.
I like this question as it poses quite a challenge! Older Echos have the left handed threads on their crankshafts (and possibly even now)...but the shaft off the gear head would really confuse people who can't remove the head anyway if it was LH and that job in itself is a challenge also. Do you have any hardware that will thread onto it?...never seen an old Toro before! yes, 3/8 24 is a pretty standard SAE size...but certainly the Toro shaft could be close to that and some other size entirely > I hate to think in terms of metric on this.
Aug 12, 2010 | Toro& Electric String Trimmer
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
May 15, 2010 | Toro& Electric String Trimmer
Case won't opem
Jun 09, 2009 | Toro& Electric String Trimmer
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Sep 11, 2008 | Toro& Electric String Trimmer
Toro& Electric String Trimmer Logo
350 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
