Question about Zebra LP 2844 Thermal Printer
I have an LP2844 and I have installed thenew drivers, but I can't get it to print. I just need to print out of excel or word, nothing fancy...running windows vista
  • nateormond Feb 06, 2010
    Thanks! I am using a USB cable - do I need to use a parallel port cable instead?
    President:
  • 3,278 Answers
Hello, Nate.
I would suggest that, in Printers and Faxes, you delete the LP2844 icon.
Disconnect the printer's cable from your computer.
Restart your computer.
Reconnect your cable to your computer.
Your computer should 'see" the printer.
Install the printer's new driver.
Hope this helps.
Posted on Feb 04, 2010
  • NinaE Feb 06, 2010
    Hello again, Nate.
    You can use serial, parallel or USB connections. So, USB is good.
    Thanks for using FixYa.
How do I use Excel to pring labels with the Zebra LP2844?
I'm going to assume you can already print from the computer to the Zebra. I am also going to assume that since you have Excel, you also have Word. The first thing you need to do is layout the labels in Word. I cannot be more specific because I have no idea what size labels you are using.
Create and print labels
Next you need to merge the values from Excel into Word
Mail merge using an Excel spreadsheet
Here are some videos that might help
Mail merge Word
Feb 16, 2017 | Zebra Office Equipment & Supplies
Hello I was working on Zebra LP2844 label printers. I need to print labels and barcodes from a data source using EPL.I have never done this things before so any help is appriciated
Epson standard code is totally different. EPL is Eltron printer language. I've not programmed in it, but there should be a programmers manual out there somewhere.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
Zebra only prints after restart
UPS VOLTEGE PROBLEM PLEASE INSTALL HIGH VOLTGE UPS
Apr 13, 2012 | Zebra LP 2844 Thermal Printer
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
When I print either a word doc or excel I get nothing printed but only garbled language as 1 line sentence on the paper: Something like this: AQKM!SEU!QAGEQSOUECU=AUUOAQKM!SEU!SESOMUUIOO=711AQKM!
Is it printing like that only on Word and Excel? If not you better uninstall the printer driver and reinstall again.. sometimes installed drivers get mess up specialy if we have done some updates or installation in other software.
Thanks
Mar 19, 2011 | HP LaserJet 5L Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Jan 14, 2009 | Office Equipment & Supplies
NEED THE DRIVERS FOR MODEL NO LP2844 ZEBRA
I have found that some times the zebra driver don't work well with Xp or Vista. Try these drivers :
http://www.seagullscientific.com/aspx/thermal_95.aspx
They have never let me down.
Dec 22, 2007 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
