Computers & Internet Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having difficulty getting my Gigaware Micro Projector to focus properly. Turning the focus knob has little effect and the picture is not very sharp. I have only tried the RCA jack video input thus far.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
300
Points
Dude,,open it up and remove the focus casing!now you can focus to any size!!down side is lens will not be attached n can fall out,worth the risk for the price n to have a ten foot screen
Anonymous
Level 2:
New Friend:
  • Expert 163 Answers
  • Posted on Feb 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
163
Questions
0
Helped
32871
Points
474
Check your zoom range to make sure you are within an acceptable range in order to focus the projector.
How can I focus it other than using the focus knob
The focus knob is the way you focus overhead projectors. Perhaps you simply haven't turned the knob far enough? How far is the projector from the screen? If it's quite close, you need to turn the knob to raise the lens. If far away, turn it to lower the lens.
2answers
Elmo overhead projector
Move the projector away from the wall, the picture gets bigger. Then use the focus knob at the top to get a clear picture on the wall. Then use a camera to take a picture of the wall. Then upload the picture to the place you want to transfer it to.
I have a galileo FS 135DS 1100 X 135mm and am having difficulty getting it into focus. I have no user manual. What can I do besides addjusting the appiture?
You focus by turning the focus knob -- on the side of the focuser. Practice during the day time on a distant object.
Mar 20, 2011 • Optics
1helpful
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
2answers
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
2answers
Sanyo projector image problem
Can you describe the issue?
check out fixmyprojector.com
they can fix this problem for you!
3helpful
Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Can't get to focus.
I think that the focus shaft has become un-attached by turning too far. Try placing the telescope facing directly upwards and start turning the focus knob clockwise. A little vibration on the tube will help the mirror to settle downwards. This may get the threaded rod back into the knob.
1helpful
Out of focus center of picture
Hi there
This could either be a bit of dust on the inside of the lens or the LCD's
Grand Canyon Tech
Grand Canyon Tech
