Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
My internet keeps disconnecting every 5 minutes
My internet keeps disconnecting and although I tried all the troubleshooting steps, and everything else provided by technical support it still disconnects every 5 minutes.
  • rob_jenkins May 11, 2010
    Who is your ISP? Is it your router that is losing connection or your local machine? Are you connected wirelessly? If so have you tried connecting with a wire?
    Scholar:
  • 117 Answers
Are you using Vista? If so, an unstable internet connection is usually the result of the router not being able to handle the DCHP BROADCAST FLAG. This is enabled by default in Vista (disabled in XP). Go here to change the setting in your registry and you should be good to go.
http://support.microsoft.com/kb/928233
If this solution proved successful, please rate my post. ty.
Posted on Feb 25, 2010
  • 163 Answers
This could be to do with what your using it for.
Different routers are made to handle different types of use.
Hope this helps!
Posted on Feb 04, 2010
  • 298 Answers
Intermittent wireless connection is usually due to signal issue, interferences, and probably a faulty firmware or hardware.
If you already tried changing channels, resetting the router, and most importantly upgrading the firmware and this did not help we can say that it might be already a problem with the device.
I am assuming that there is no issue with the distance, obstructions, and computer getting an excellent signal strength experiences this.
Posted on Feb 07, 2010
My garage door light stays on all the time after opening or closing the door.
The light can stay on for a number of reasons .. especially depending on how many features your opener has. If your opener has a lot of features ... take a look at your owners manual and some feature may have been inadvertently activated that keeps the light on.
However ... if everything is set up correctly try the following to help narrow your root cause down.
If you can change the delay time of the light ... reset it to the lowest time value which just helps in troubleshooting. Most are set for 4-5 minutes which is along time to wait if your troubleshooting.
  1. Disconnect power from the unit, and disconnect door control wires from the opener.
  2. Reconnect power only. Light(s) should come on. Allow light(s) to cycle off.
  3. If light(s) turn off after delay time, the problem lies with either the door control or wiring. Continue with next step. If the light stays on, it is the logic board.
  4. Disconnect power from unit. Remove door control from wall, connect to operator via a known good short pair of wires. Reconnect power only. Light(s) should come on. Allow delay time for light(s) to cycle off. If light turns off, it's a wire issue. If not, the door control should be replaced.
Mar 16, 2018 | Building Materials
I have a black view ultra a six the Internet is moving extremely slow I'll do I speed it up reviews I've read set the Internet should be equal to something of an iPhone please give me any assistance t
Hi, Try with the following basic steps for better internet connection.
1.) switch off your mobile and switch it on after 5 minutes
2.) Clear your Browser history, cookies, cache
3.) Browse through a latest browser
4.) Check the RAM memory
5.) Disable background running apps
You can check your internet speed from ScanMySpeed.com before and after performing these steps. You will definitely see improvement in speed.
Feb 04, 2015 | AT&T Computers & Internet
I cant reset my bios mine has 6 pins and two jumbpers how to i reset them
Step 1:
you can remove cmos battery from your motherboard to reset every bios setting.
Step 2:
disconnect all power wires from your pc. first open your case.
Step 3:
now , remove cmos battery and leave it for 5 to 10 minutes. after that put that battery again and start your pc.
Step 4:
now open bios menu at startup. you will see everything resetted.
Apr 11, 2013 | Computers & Internet
2003 sierra gauges not working plus dash plus drains my battery any suggestions ?
Try this simple trick. Shut off every thing in your vehicle, radio, ac, lights, windshield wipers etc.Turn off the vehicle put it in park. Disconnect your battery , wait 5 minutes. Then Without turning any thing on leaving the vehicle in park reconnect the battery start the vehicle and let it Idle for approx 10 minutes. This allows your computer to reset all of your gauges. By assuring that everything is off your computer can concentrate on resetting everything correctly without missing a step . This will set your Idle and all of your Gauges. Whenever your battery is disconnected for what ever reason this step should be followed immediately upon reconnect.
Nov 16, 2012 | 2000 GMC Sierra
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Wireless-G WRT54G Router: I lost internet connection from router. Everythin...
Unplug both router and modem. Disconnect modem from router. Wait 5 mins and reconnect everything.
May 18, 2010 | Linksys Wireless-G WRT54G Router
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
My son has an Xbox 360 - keeps disconnecting from the internet about every 3 to5 minutes... we have been told it could be something to do with the set up of the Belkin wireless G plus mimo router?
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Jan 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
1,940 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
