Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
Trying to connect to the internet with my netbook via a netbook external modem. System does dial up but then tells me not permitted on the remote access server. It's still trying to look for a network connection even though Dial up is selected... Help
  • grehmer May 11, 2010
    Why do you need an external modem for a dial-up connection?
  • 369 Answers
Click start, go to run and type ncpa.cpl. Now, if you see any dial connection icon, delete that. Now connect the cable again and check it.
Posted on Feb 05, 2010
I am trying to connect to my virgin mobile internet via the virgin mobile flash drive, the netbook isn't even picking up that I have the flash drive plugged into the computer.
If this is a Sylvania Netbook running Win CE 6 it is possible that the operating system simply doesn't have a driver for Virgin Mobile cellphone.
The only way I have been able to connect to the internet is via Wifi or a LAN cable plugged into the back. I doubt you will get any other method to work.
Please note the Wifi can be via a Wifi access point on your cellphone, a portable, mobile hotspot that connects via a USB modem or any other functional Wifi access point.
Tom M.
May 03, 2011 | Sylvania G-Netbook
Do i need to buy a external modem for my netbook to go online
First you need to check if your netbook has a wireless switch, it used to be in front or by the side or in front of the laptop, if it does, all you need to do is to turn it on, and if there is a wireless network around, then you will be able to connect to the internet.
You can also the control panel to see if the netbook has a wireless switch and where it is located on the netbook, and that will simply tell if you do have wireless service on your netbook.
From the sides of the netbook, there is an internet port, if there is no wireless switch, then you can connect any local connection available in the internet port that is by the side of the netbook.
But you need to ensure there is a local connection somewhere, and the router is working correctly, then you can use the local cable connection, but if there is none, then you will have to buy an external modem for the netbook to go online.
I hope this helps.
Dec 21, 2010 | Sylvania G-Netbook
Error code 651
Error code 651
This error corresponds to an error in a modem or any other connecting device
Try the folloging the instructions below:
If this is a dial-up connection, and you are using a supported external modem, turn off and then restart the modem. Close and restart Network and Dial-up Connections, and then redial. If the problem persists, try connecting at a lower initial speed. See To change the maximum modem port speed. Make sure you correctly configured your modem for remote access. To check your configuration, see To configure a connection. If this is a virtual private network (VPN) connection, you might have specified an incorrect TCP/IP address in the connection configuration, or the server that you are trying to reach might not be available. To determine if the server is available, see your system administrator.
Oct 18, 2010 | Computers & Internet
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
I have only a dial up connection and the telephone connector cable does not fit anywhere on the Netbook Please help!!
More than likely the Netbook does not have a "Dial-up Modem" installed. They are usually equipped with a wireless network card and/or a network card. Will have to go with an external USB modem to use your dialup. To be sure I would need the make and model of your Netbook.
Jan 02, 2010 | Acer Aspire One PC Notebook
I know this is a stupid question...but does my laptop need to have an internal modem to connect to the internet
well according to the specs i saw it already has a wireless lan card, an ethernet card, and a old school phone modem jack, so you should be good. are you having issues connecting to the internet via wifi?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 03, 2009 | Dell Latitude D600 Notebook
Connection a Netbook to dial up
if your netbook doesnt have built in dialup modem that mean u cant connect it to a dial up connection. most of netbook in market use wifi as primary connection or sometime comes with built in GSM modem to connect to internet. that meanc the option you can try is to buy a external USB dial up modem
Mar 26, 2009 | Advent 4211c Notebook
Cloudbook CE12ooV - Linux GOS
If your computer have a serial port connect an external modem.
Feb 10, 2009 | Everex CloudBook CE1201V Netbook
Dial up Modem
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Sep 03, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Connectivity problem
it is still trying to connect via your modem, go to control panel>network connection, and you will see your modem dialup connection, right click and select dissable if required.
next open up internet explorer, go to tools>internet options, then click on connections tab, then half way down select 'never dial a connection'.
Click apply>ok, then close internet explorer, open it up again and wait a few seconds and it will connect via your router(asuming that it is correctly set up).
If no page appears then click refresh a few times.
Aug 12, 2008 | Acer Aspire 5100 Notebook
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
48 people viewed this question
Alun Cox
