Question about Samsung HCM5525W 55" Rear Projection Television
Picture not perfectly clear
Picture looks fine in the middle but double in the side
    Sergeant:
  • 395 Answers
Your convergance ampliers have gone bad and need to be replaced along with some resistors and/or pico fuses. the repair my cost you about $350.00. this is the most common failure in rear projection tvs
Posted on Feb 20, 2008
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
My Sony Bravia KDL-52W3000 when turned on after being off for a while has a weird double/distorted picture for about 15min. then it clears up and has a perfect picture for the rest of the time you watch...
CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
Take care.....
Aug 04, 2011 | Sony BRAVIA KDL-46V3000 Television
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
Convergence, picture is warped on the sides, double images or ghosts, clear in middle
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2010 | Sony KP-51WS520 51" Rear Projection...
The middle of the picture is fine but the sides of the picture look like they are double with a red outline
The TV has a convergence problem, the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Thanks for choosing FixYA, Big Irish.
Nov 22, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture Problem!! and its not convergence (Double vision except for middle of screen)
Could be pin correction circuit or your picture tubes could be worn out . Sometimes when the crt's get weak the edges seem not as clear as the center of the screen . Give model number if you think the pin correction may be your problem but, the tv is pretty old and avg. life for them is 12 to 15 years when the picture tubes start to degrade . Good luck
Mar 01, 2008 | Sony KP-61S65 61" Rear Projection...
Picture looks fine in middle but the sides doubles
zenith 55" projection tv. approx 8yrs old.
the right half of picture is normal the left half of picture is blurry or shows double or triple vision.
Feb 13, 2008 | Televison & Video
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
