Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Vertical colour bars
I have a westinghouse wide screen hd tv modelSK-32H24S , when tv warms up approx 15 min i get vertical colour bars no picture,shut tv down for a while turn back on picture ok till warmup again then colour bars apear again!!!!what could be the problem? tv only 1 1/2 years old and not used every day!!!!
  • 11,361 Answers
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Posted on Feb 05, 2010
  • learnme Mar 27, 2011
    I have vertical color lines on my 32 LCD westinhouse as soon as I turn it on. It Needs to heat up for for an hour, sometimes little longer then my picture will come back.
    what could this be?
    thanks,
    j
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vertical color bands take the place of the picture.
I sent my question to the "solve your problem for free" on this website, so I was expecting some "free" advice. My finances are such that I can only ask for free advice. I did see someone who had a similar-sounding problem, and there was a mention of two possible main boards that would fix the problem. I was hoping to know which board would most likely fix my problem, since the TV is less than two years old. If I take it to a TV repair person, I want to have a fairly good idea how to fix it, and what would be the approximate cost, so I do not get ripped off.
Jan 07, 2009 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Tv goes off after it warms up AND pic. goes SHORT and WIDE prior
im betting the vertical deflection is failing, a capacitor that is in the vertical deflection circuit may be dry and as it heats up shorts shutting the tv off.
Dec 12, 2008 | Philips Magnavox 27MS343S 27" TV
Picture problem
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Mar 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Jan 16, 2008 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
351 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
