Question about GE Profile 21.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22PRBWW
Side by Side GE Profile 21.6 cf refrid- temps good on both sides but heavy frost building on back wall of freezer- and it is running all the time. When you attempt to adjust the temp via the controls, freezer will not go off until set to zero. I think this may be due to the frost build up. Should I replace the defrost control (WR09X0489), thermostat (WR50X0122) and heater (parts list has Defrost Heater & Harness (WR51X10031) and Defrost Heater & Bracket (WR51X10032) what's the difference between those two)? Thanks
  • 604 Answers
Harness is wiring,eplace the defrost control and make sure the door seal doesnt leak
Posted on May 06, 2017
  • 248 Answers
SOURCE: Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Posted on Nov 14, 2007
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jun 24, 2009
  • 135 Answers
SOURCE: Hello - and thanks for taking the time to read my
If the heater is working, then either the defrost thermostat is bad or the defrost timer board is not functioning correctly.
Posted on Aug 26, 2009
  • 166 Answers
SOURCE: My ge side-by-side refrigerator/freezer isn't
Yes that is right. Turn the Refrigerator off/ unplug it. Remove the rear panel of the freezer and thaw out the coils with a fan or hair dryer.
The most common problem is with the defrost heater. Using an ohm meter check the heater for continuity but unplug the 2 wires (one from each side). This should be a glass encased heater. you can also very gently pull both ends of the heater and if it is bad it will come apart instead of feeling "springy". If you have only one heater your new replacement will probably be a 2 heater kit.
Posted on Jun 16, 2010
  • 166 Answers
SOURCE: GE side by side has ice from top to bottom on
It shouldn't burn out that fast but may have. Some of the side by sides came from the factory with only one heater. Later on it was decided that the replacement heater kit include a second heater. This could be the case for you.
Posted on Jul 12, 2010
Check for frost build up on the back wall of the freezer. This is a sure sign of a defrost problem. Is the fan running? Check the defrost heater for continuity. If you have continuity at the heater, there is a very good chance the main circuit on the back of the fridge needs to be replaced.
Aug 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Apr 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model 106 56569400 - Freeze side appears to be Ok. Refrig side not cooling to set temp 37. Current temp is 55-60. Door appears to seal properly.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Jan 27, 2010 | Refrigerators
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dripping inside of freezer, forms ice-cicles, water doesn't dispense and temp. rises on both freezer and refrigerator.
Check rear inside wall of freezer for frost build up, this prob is an indication that you have a defrost problem, like a bad defrost heater or defrost control.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer at 21 degrees , refer at 44 degrees, will not get any colder.
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Sep 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge refrigerator & freezer not cooling - frost build up on back wall of freezer
You probably have a bad defrost heater behind back wall of the freezer if you turn the unit off and let it defrost a fan will help speed this up the unit will run for about 2 weeks giveing you time to get a defrost heater GE have glass tube heaters and they are bad about going out good luck
Mar 31, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
