Question about Whirlpool Dryers
My Whirlpool dryer run, blows air, but no heat. Do we need a heating eliment? It's about 5 years old runs fine, but all of the sudden, it stopped blowing hot air. It has the air only function, low, med. and high functions. I had put a comforter inside to dry (had done this before with no issues) and went to check on it and found it still wet (not damp) but cold. I discovered the machine runs and blows air but no heat.
  • 572 Answers
Could be a thermal fuse
Posted on Feb 05, 2010
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
265 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
