Question about Pioneer DV-444 DVD Player
Front dislay not working properly. It turns off, while the DVD player works ok.
  • natrap Feb 05, 2010
    dsimba2002 thank you for your answer.
    No, it is not broken.
    When I insert a disc on the player the dispay works ok.After a few seconds,the dispay turns off. When I use the "display" button on the remote, the dispay works ok for a few seconds.
    Is there any other way to fix the problem than to open the deck?
Is it broken if not open the deck and then check diodes and trans
Posted on Feb 04, 2010
DVD player frozen
might be there is a fault in DVD. Also try to clean you DVD player's lense.
Dec 18, 2013 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Screen display
sounds like you need a new dlp replacement bulb they go out after about 15 months
Apr 28, 2010 | JVC HD-56G787 Television
The DVD side will not recognise any disk i offer it to record to it shows a circle with a red x on it dislays that the disk is blank on the front panel
Make sure you are using the right kind of discs check the manual My player will only play the philips brand blank dvds. Also clean the player with a philips lens cleaning disc if that does not work you may, as I had, a hair on the disc spinner inside the player that caused errors.
hope this helps
gary cox
gmcox1956@aol.com
Mar 27, 2010 | Philips DVDR3430V DVD Recorder/VCR
Turns on but no buttons work at all.
Un plug it. Remove the screws from the bottom and back. Slide the cover off.
Look at the keypad in front. Could be a loose cable or the cover is not sitting on the front properly.
Good Luck
AL
Apr 26, 2009 | Sony DVP-S530D DVD Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
Replacing dvd player/burner on iLo DVDRH04 DVD Recorder
I Have ILO DVRHD04 and my front buttons sto to work when i use the remote works ok... when the unit is of I turn on from the front paner works ok try to turn off from the front buttons is not work and the lite in the front go crazy only when i pres stop & play button and on fo button... what is the problem... The remote work ok play stop edit or recodring
Mar 12, 2008 | iLO DVDRH04 DVD Recorder
Buttons on front console no longer work.
time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Feb 08, 2008 | Memorex MVD2027 DVD Player
Let my dvd player work
Have you or have someone bench tested it before installation? It is much easier to diagnose for problem when you bench test.
Oct 29, 2007 | Pioneer AVIC-D3 Car DVD Player
Pioneer DV-444 DVD Player Logo
22 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
