Question about RIM BlackBerry Curve 8520 Smartphone
My calls are coming through on my blackberry curve but not ringing just vibrating?
3 Suggested Answers
Buland Khan
  • 297 Answers
SOURCE: my blackberry curve does not ring when call is
try to reset ur phone ...if it won't work then replace ur phone ringing speaker
Posted on Nov 15, 2009
bahratt
  • 561 Answers
SOURCE: my blackberry curve wont ring it only
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues such as yours.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 15, 2010
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
No ring when phone call is received
Hello. Most likely the ring has been turned off. The volume adjustment setting goes from loud to soft to vibrate only and finally to no ring and no vibrate. The volume key is on the outside of the phone on the right hand edge.
Regards, Joe PS - kindly rate my answer as helpful. thank you.
Feb 18, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry will not ring when i receive messages! Only calls.
go to where your messages are and then hit the menu key then go down to where it says "Message Alerts" Here you can change e-mail, SMS, and MMS and all message prefrences. you can pick ring only vibrate only vibrate and ring etc etc. click back then click save
Dec 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How to get my blackberry to ring and vibrate
  • You need to check the profile.
  • Go to main screen
  • you will find options
  • under options icon you find profiles. Here you can set vibrate and ring tone
Oct 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
When I receive a call it rings only twice my end altho the caller hears about 10 rings. I often cannot get to the phone in time to answer and would like to increase the number of rings to 10.
Your profile may be set to a vibrate and tone setting. Therefore, you wouldnt hear the vibrating.
Go to Profiles then scroll to Advanced, select the profile that you are using. Scroll down and select Phone.
Where it says Out of the Holster, change the option to Tone and the Volume to Medium or High.
Aug 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Can't set my blackberry curve to ring and vibrate at same time
To silence your device
In the profile list, perform one of the following actions:
• To receive LED notification only, click Quiet.
• To receive vibrate notification only, click Vibrate.
• To turn off all notification, including notification profile exceptions and LED notification, click Off.
Hope this helps!
- CBR2009
Aug 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Ringing sound, speakerphone, completely lost
Either bad speaker or audio amplifier. Warranty.
Feb 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
Curve 8300 - my phone will not ring, only vibrate
you need to sync your phone with your computer then do a wipe of handheld. this will erase everything but since you have synced you can go and restore from the computer. make sure you back up to computer first. if this does not fix it it needs to be replaced thru warranty or insurance.
Sep 09, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8300 curve
Turn your vibrate off. The curve vibrates before it rings, it won't vibrate and ring at the same time. So with the vibrate off, you will gain about 10-15 seconds of ring time.
Apr 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Curve 8520 Smartphone Logo
319 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
