Question about WiFlyer - Portable, shareable WiFi base station for dialup and broadband Internet connections (WF1)
Connecting with a wireless router
I have recently received a wireless router wich i have connected and setup. the message in the bottom right hand corner of the computer says that the wireless connection is connected. however when i try to connect to the internet it says that the server cannot be found. i have checked with my provider and there is no problems in the area and they have suggested that i contact HP. Any advice pls
  • wibbly Feb 20, 2008
    Yeah, i have the same problem on my Compaq Evo laptop the signal indicator says the signal is very good from the router but when i try to connect through Yahoo it comes up with the page cannot be displayed and cannot fiind server, it,s driving me nuts. !!!!
  • 77 Answers
The signal indicator only tells you that you are connected to the router. You need to make sure that your router is connecting to the internet. go to it's configuration page by browsing to http://192.168.0.1 (note that this address is correct for many routers but not all, check the manual to be sure) find the tests or diagnostic section and run the connection test.
Posted on Feb 20, 2008
Hi - I recently set the security on my router but am having trouble connecting to wireless on my home laptop. All other devices seem to be ok (2 work laptops, IPad, Ipod) and I get a message saying that...
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Jan 04, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I need help connecting a Linksys router # WRT610N to a MAC
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Sep 15, 2010 | Linksys WRT610N Wireless Router
How do I connect the second computer to the internet ?
If your connecting a second wired computer , all you need to do is plug an ethernet cable on ethernet port of your computer and the other end should go to any of the available ports in the back of your router.
If you connecting a wireless computer. You just have to look for the wireless icon, its usually seen on the bottom right hand corner.
Right click on the wireless icon and click view available network,
Highlight your network name and connect.
Cheers
KJ
Jun 20, 2010 | NetGear DG834G Router
Having a problem connecting
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 17, 2010 | Linksys Wireless-G WRT54G Router
Trying to connect lap top to router
Problem connecting to the wireless network?
What is the Operating system on the laptop ?
Apr 18, 2010 | 2wire (1000-400108-001) Router
I purchased the Airlink 430W on Friday. After receiving assistance from the company on setting up the router it worked fine. The next day, there wasn't a connection to the laptop. I reset the router and...
try connecting fromn the laptop end. in your tray (bottom right hand corner of screen) there is a little icon with semicircle waves coming off it, right click and
"view available network" find the correct network name in the list and press "connect" button
Mar 21, 2010 | Airlink AR430W Wireless Router
My laptop is not connecting to the belkin G router
Jan 07, 2010 | Belkin Computers & Internet
Wireless not working will not let me on the internet
How to connect to the wireless network?
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Dec 10, 2009 | Linksys Wireless-G WRT54GS Router...
Asus wl 600g
Nov 15, 2009 | ASUS WL-600g Wireless Router
Experiencing error when connecting to wireless router
I've had this happen before when using a USB wireless device. Is the wireless on your system built in? Or do you connect it to a USB port? The external devices sometimes try to use their own software to configure wireless so you can shut it off and just use the Windows wireless tool. I assume you setup the wireless with a security key and entered that key into your system to try and connect? Let me know if any of that helps and rate the solution if it does!
Mar 31, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
214 people viewed this question
Top WiFlyer Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a WiFlyer Computer and Internet Expert? Answer questions, earn points and help others
