Question about Kodak EasyShare C743 Digital Camera
What memory card can be used
Can this Kodak C743 camera use a dny memory card if so, how do I get it to work. It keeps saying to format, and when I hit the format, it does not work. Help !!!
  • kakima May 11, 2010
    This camera uses SD cards, which top out at 2GB. Are you trying to use a larger card (technically, an SDHC card)?
    Brigadier General:
  • 11,967 Answers
Make sure the slide switch on the side of the card is unlocked.
Posted on Feb 04, 2010
I just purchased a SanDisk 8 GB SDHC card for my Kodak EasyShareC743. When I inserted it, it said it needed to be formatted, I hit continue, then is said it would delete anything on the card, I hit...
The C743 works with MMC and SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to go with cards 2GB and smaller.
Jul 07, 2011 | Kodak EasyShare C743 Digital Camera
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
Can i use a 4gb memory card
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00606/C743_GLB_en.pdf
P.50 of the above manual has a table that goes up to 1 GB for an SD card.
But, the FAQ's say that Easy Share cameras can use up to 2 Gigabytes for the SD cards.
Since your camera is from an XP Windows System era, I wouldn't expect that a 4 gb SD card would work in your camera (since it is that old).
http://selfservice.kodak.com/service/panels/solution/printSolution.jsp?solutionId=1170&t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&viewMode=NORMAL&windowType=SAME&highlightInfo=&isRecord=false
The FAQ seems to indicate, again, that 2 Gigabytes is the maximum for an SD card (which your C743 digital camera uses).
The instruction manual seems to indicate that 1 Gigabyte is the max in the table.
Therefore, I would try the 2 Gigabyte one and if it doesn't read or format, then I would use the 1 Gigabyte as the max. for this camera, and return the 2 Gigabyte SD card.
Aug 08, 2010 | Kodak EasyShare C743 Digital Camera
I just bought an hp 4 gig sdhc memory card for my kodak easyshare c743 camera. Will it work or should i return it?
The C743 works with MMC and SD cards, not with SDHC card. Your 4GB card will not work in it. You can return it or, if you have another device which can use SDHC cards, keep it.
Jun 29, 2010 | Kodak EasyShare C743 Digital Camera
Kodak C743. Loaned to friend, now camera has disk
how big is the memory card you are trying to use?
the max size for the C743 is 2GB
try to format the card in a card reader
Jun 04, 2010 | Kodak EasyShare C743 Digital Camera
EasyShare C743 Digital Camera: I just bought a new 8 gig Kingston SD card for my ...
The C743 is only good to 2 GB other models of Kodak can use the larger cards but not the c743
May 17, 2010 | Kodak EasyShare C743 Digital Camera
Have a Kodak EasyShare C743, bought a SanDisk, won't format
Your camera was designed before the SDHC format came out. Sorry, your camera can only use standard SD cards, those usually 2GB or less. An SDHC card will not be recognized properly by your camera. If you really want to use a 4GB card, do a Google search for SD and "non hc", with the non hc in quotes. Believe that Transcend makes one.
Apr 24, 2010 | Cameras
Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Nov 28, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
99 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
