Question about Car Audio & Video
What amp to use to power my MTX Terminator Subs?
I recently bought two 12'' MTX Terminator Subs and am now looking into what amplifier I should pair them with. I've read some reviews, and it seems that the Terminator amp isn't actually demonstrating the full power of the subwoofers.I have 8 gauge stinger wiring, but I realize I may need 4 gauge. I'm looking to spend $100-$180 on the amp. Here's a link to see the specs of my subwoofer package (without the amp):
http://www.onlinecarstereo.com/CarAudio/p_19669_MTX_Terminator_TNP212D.aspx
Thanks
  • 102 Answers
Hi i use rockford fosgate amps they are the best you can get a great punch amp on ebay that will hit them great try seller> fingerz022 on ebay i bought mine from him and its hitting my 15"s nice...
Posted on Feb 05, 2010
  • michael whitman Feb 05, 2010
    oops im sorry hes called fingaz022 heres a link to his ebay then i would hit the ask seller a question then tell him about the subs you have and he will sell you the right amp for them at a great price..>
    http://shop.ebay.com/fingaz022/m.html?_d...
  • Muhammad
    Muhammad Apr 13, 2017
    look if you are searching for the perfect amplifier to power your sub you should check this reviewhttp://loudnoisycar.com/best-rockford-fo...
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
I recently purchased the mtx terminator amplified bass system and wired everything in, but the amp seems to not be working, i checked the power and the wires going in are a good circut but none of the...
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
May 05, 2011 | MTX Car Audio & Video
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
Not working
disconnect the subs from the amp and check to see if the amp will turn on and stay on-check the subs to see if they are blown with a different source try a pair or a single sub that you know works fine on the amp and see if it plays-this should tell you whether your amp is fried or your subs are roasted
May 19, 2009 | MTX 4002 Car Audio Amplifier
Just got this amp, and was wondering what subs I should get with this amp
Did some research and it sounds like a wicked lil amp with clean clean sound-its hard to say what subs to tell you to run because everyone has different taste- and without knowing what your setup is going to be theres no real way to actually say-the amp is made to run 3 channels -so focusing on the sub channel only i personally say get a pair of 10s or a good 12-your not throwing a ton of power so you dont have to go balls out on the subs- i personally like MTX subs and xtant is made by MTX so that wouldnt be far from home -good luck with that
May 19, 2009 | Xtant 403A Car Audio Amplifier
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Jul 12, 2008 | MTX 6001 Car Audio Amplifier
Car amplifiers
connectors on the rca's are bad. need to be changed out
Jul 11, 2008 | MTX Car Audio & Video
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
583 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
