Question about Hotpoint WMA35 Front Load Washer
Hotpoint WMA35 - water will not empty and will not spin
Hope you can help, the drum is going round as it does to wash but the water will not drain from the drum and it then will not spin.
Can you tell me what the problem could be and how I can drain the water from the machine please
    Problem Solver:
  • 3 Answers
Hi Debbie
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Posted on Feb 20, 2008
    Problem Solver:
  • 8 Answers
Hello deb it sounds as if the drain pump has either gone or possibly blocked , it is also possible the outlet hose is blocked. your machine should not SPIN with water in the drum any way . hope this helps u . regards BTW
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum won't empty
Check drum something may be caught on heater not allowing water through quick enough, take sump hose off and look onto drum.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Drum wont empty...have checked pump, seems to be working becasue some water is being pumped out..have checked filetr to pump and removed a couple of small buttons..outlet hose seems fine because initial...
It obviously is related to the pump and outlet hoses.
If it is a tap in waste then check for obstruction there,
Remove drain hose completely and run water though it to make sure it is fully clear.
Check inside the pump itself for any obstruction , if you are satisfied that every thing is o/k, then as a last resort, fit new pump.
Plz leave feedback for this solution.
Thanks.
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA35 Front Load Washer Logo
408 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
