Question about Maytag Dishwashers
I turn on and nothing happens - Maytag Dishwashers
  • 129 Answers
Do you have 120 volts power to washer ck door andle has 2 switches inside 1 switch at water valve
Posted on Feb 05, 2010
Car wont start cant move shift out of park new battery and plugs
nothing happens means the starter is Silent?
yes silence happens. ?
after all nothing is zero , how can zero happen,??? LOL.
the operators guide covers this.
how to crank in neutral, read that yet.
you must have what.?
1: fuses good.
2: charged battery. is it, ???? 12.6vdc rested?
3: brake fuse and working brake lamps. are theY?
this is called park lock out feature.
id dont have liberty books. zero.
nothing happens when i look for this book, LOL
on older jeeps there was a magic bypass device, for emergencies, but the dam(n) gov , made that ILLEGAL, like most things now.
I get lost here
I cant shift to neutral, or can
and if can shift to neutral, does the starter make noise.
that, GGGRRRRRHHHHAAAAA sound....
makes the crank shaft turn. even seen to turn....you can...
Dec 27, 2015 | 2005 Jeep Liberty
When turn key nothing happens
check connection and wires at battery for damage or corrosion if good check for power to ignition switch if no power check for damaged or shorted wiring if good turn key and check if power going to relays or accessory's at fuse panel if no power switch may be bad
Apr 08, 2014 | 2002 Saturn S-Series
Honda civic 1995, you turn the key and nothing happens, just replaced the battery.
honda civic you turn the key nothing happens,no dashboard lights nothing,battery all ok but car is dead
Apr 24, 2010 | 1995 Honda Civic
When I turn the key, nothing happens. battery is
your starter needs replacing not to hard of a job to do yourself
Jan 24, 2010 | 2000 Jeep Cherokee
Turn the key and nothing happens, waited a few minutes, turned the key again and it started
It could be the switch that the key goes into is wearing out.I hope this helps you.
Sep 04, 2009 | 1999 Jeep Cherokee
1995 toyota 4 runner starting problem once in awhile
Is the starter turning over the engine when it wont start or is nothing happening at all?
I might have your solution if I have more details.
If the engine is turning over but not starting then switch on the ignition and push it to start.If it starts you probably need a new ignition switch.
Please get back to me .Thanks
Aug 04, 2009 | 1998 Toyota Corolla
Matsui MAT 140 MR wont turn on
If you can check the rechargeable batteries try that. If you plug it into a wall socket with the adapter and nothing happens you might have other major problems. Just a little education: when you buy something especially from other countries alway check it before leaving to make sure it works. Unless there is a company that you can send the warranty unit to you may be out of luck. Sorry.
Jan 14, 2008 | iLO (2 GB) MP3 Player
Dishwashers Logo
79 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
