Question about Nintendo Wii Console
Having a problem getting up my wii internet - Nintendo Wii Console
  • 864 Answers
Try this Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
How do i get the internet on my wii
goto the setup menu,it will ask you if you have internet connection,turn on network discovery on the wii,this will find you internet connection,after that it will ask you for the connection password,type this into the wii and hit the connect button,now you have your wii hook-up to the net..
Dec 24, 2012 | Nintendo Wii Console
How do I get Internet connection on my wii
Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note that in order to connect to the internet on your Wii, you must have a wireless router or wireless internet connection, via that's the only way a Wii can access internet!
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
I cant get the internet to connect to the wii
I'm getting Error Code: 51420 when trying to connect to the internet with the Wii console.
This is our first time trying to make internet connect with the Wii console. I have a USB cable connect from Wii console to the Modem. Any help
Jul 16, 2011 | Nintendo Wii Console
Im tring to download the internet to my wii
To get the Internet Channel for Wii, you must have an active network connection for your Wii. Then you need to go to the Wii Shop Channel. Here you will have to browse to find the Wii Internet Channel, and click to download. Once it is downloaded you can use the internet channel as normal. Have a great day.
Jun 21, 2011 | Computers & Internet
How do I connect the wii to the internet?
I don;t know what you are downloading. If you can get to the Wii Store then you already have an Internet connection. Otherwise, just go to the system menu, to Internet and use the connection wizard to help you set up. Make sure you have the keys and authentication type correct.
May 02, 2010 | Nintendo Wii Console
I cant get on to the internet
o.k I to at first did not know how to get on the internet but it is not too hard.
first there is only two ways to get on the internet using the Nintendo Wii.
(1) you can easily connect to internet if you have a wireless connection in your home.
(2) you must purchase a USB Ethernet adapter. this adapter plugs into the USB port on the back of the Wii. You then must have a router with a port available. Run the Ethernet cable from the Wii connector to your available port on your router.
For either connection you then go into your Wii options ang continue into settings on your Wii. make sure you then chose the arrow to go to the next page. Click internet, connection settings, click connection 1 to set up. chose wired or wireless connection, It will then initiate a test and if all is good you will now have internet connection.
if you still have problems visit the wii website
here is a demo :
Click here
or heres the link:http://us.wii.com/connect/
this should help you!
Mar 25, 2010 | Nintendo Wii Console
Have just tried to connect the wii tothe internet
to connect the wii to the internet you go to wii settings then find internet then there should be connections use connection 2 and set it for wireless then search for your router then input the security code which is on the back of the router which is wpa-psk or wep key then start the search then it ll upgrade then jump back to the wii main menu then you should be able to access the wii s online features
Jan 24, 2010 | Nintendo Wii Console
Wii Internet Connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jan 13, 2009 | Nintendo Wii Console
Cant get our internet to work on our wii
go here for some really good screen shots on how to get your wii online
I hope this helps
Dec 25, 2008 | Nintendo Wii Console
I don't know how to get on the internet with my wii
first you need to have a broadband internet and go to wii settings got internet try to connect to a internet then go to wiishop channel and and put some wii points then download internet channel it cost only 500 points and thats it
Aug 26, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
15 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
