Sharp AR161 Copier Printer Problem
My copier works fine but the printer will not function. The LCD display which would normally display 'ready' or 'menu' is totally black, ie all LCD segments are lit and the orange and green leds at the side of the input cable are permanently flashing. There are no documents queing to be printed and I have rebooted both the printer and computer.
Is there an engineer reset code or does it sound terminal.
Any assistance would be a great help.
Thank you
Chris
  • Anonymous Apr 11, 2008
    The printer used to work well, downloaded driver software, up from sharp site, in order to get full function is especially scanning.
    Everything is carefully well connected with high quality cables, and even drivers made available through vista in the printer wizard, now they can talk to each other. Printer still works great on its own, but computer and printer won't work together. Only additional piece of information that I haven't This point, is that driver software did not have a digital ID, according to Vista.
  • 29 Answers
Reinstall your printer in to your computer and try the test print.
Posted on Feb 24, 2008
My Copier Sharp MX-2700N displays print quality Automatically adjusted and it wastes so much time to initialize. How do i fix it?
might also be the it has to have its firmware re-flashed have tech come and check it out and have a good cleaning done.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 12, 2015 | Sharp MX-2600N Laser Multifunction Printer...
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
The copier can not print
the copier 5316 does not work with win7.you should have win xp on your pc.uninstall the driver.unplug the usb cable between you copier and pc.insert the cd and install driver again.then connect the copier to your pc.check if there is not any error code on your copier display.
Aug 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error light h-4 ar161
press(# interrupt C interrupt)lcd will turn off.enter 14 and press copy key
May 09, 2010 | Sharp AR-M160 Black and White Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Sharp SF 2314 Copier
A U2, is normally caused by the toner cartridge not communicating with the main board.
Try removing and re installing the cartridge a few times.
If that doesn't work try replacing it with a new cartridge.
The memory may have dumped also. In that case a new memory or main board would be required.
Jan 17, 2008 | Sharp SF 2314 Copier
PRINTER PROBLEM ON E-STUDIO 211C
please reinstall the printer again may be it is GDI
Sep 23, 2007 | Toshiba E-STUDIO 211C Copier
52 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
