Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Jabra head phone is not working. Do I need to replace the battery and if so, How?
  • 1,428 Answers
This device is basically designed to spoil and there are no ways for you to open it up and replace the battery.
Usage determines the life span of the battery. Get a replacement unit.
Good luck and thanks for using Fixya.
Cheers.
Posted on Feb 04, 2010
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    I have a Jabra Clear that won't match up with my phone
    The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
    Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
    Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
    Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
    Nov 11, 2014 | Jabra Products - BT2080 Monaural...
    I am working for a company and we bought about 2 dozen jabra bt2020 head sets, i just worked trough about a dozen of them to find out not one is working. The blue light goes on for 3 seconds when i try to...
    this might be the issue you are having
    Cons: BT is supposed to work at 30'. Could never get more than 10' away from a phone. Worse, their batteries short out & will not hold a charge and the unit will not turn on after 6-8 months, max. I know as I have had 6-7 units all with the same result.
    here is the link
    http://reviews.cnet.com/headsets/jabra-bt2020/1707-13831_7-32742719.html
    Sep 24, 2010 | Jabra BT2020 Bluetooth Headset
    How to pair the jabra BT125 headset with personal computer to here songs without using head phones
    hi vrajasekar20, thank you for using fixya.
    to pair your jabra to a PC for headset use, you have to install the jabra PC Suite first and use it as your default sound input / output device.
    The PDF file below will give you a step by step instruction on how to have it installed and working.
    http://www.jabra.com/sites/Jabra/GNimages/Products/Adapter/A330/A330_FAQ_EM_EN_2838.pdf
    Should you need more info on this matter,please do not hesitate to let us know.
    regards,
    voodoo
    Apr 17, 2009 | Jabra BT125 Headset
    Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
    You can solve this by connecting your phone inline.
    On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
    When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
    Oct 28, 2008 | Jabra T5330 Wireless Headset
    Help
    Jabra corded head set are not as that compitable in motorola cellular phones.as compare to the nokia 8000 or nokia 3000. so basically it may create problems.. cheers!!
    Jun 06, 2008 | Motorola Mobility C168 Cellular Phone
    English instruction manual
    you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
    Nov 28, 2007 | Jabra BT8010 Wireless Headset
    Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
    Top Jabra Radio Communications Experts
    TO Lady
    Greg Cann
    Greg Cann
    Michael Vincent Cruz
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
