Question about KHypermedia (KHCRW522452) (20326452) CD-RW Burner
KHCRW 52 24 52 CD-ReWriter not recognized
I took an CD rom from a HP Pavilion and installed a KH CRW52X24X52 CD-ReWriter. The jumper was change to CS to match the one on the CD Rom that I took out. When I powered it up I put the install CD in and it just sat there. I went to MY Computer and it doesn't show there. I when to the device manager and enabled both channels like the book said and no change. The system just doesn't want to see it.I've used the wizard but it doesn't see it. How do I correct the problem?
Terry Stimmel
TSti402923@aol.com
    Genius:
  • 1,019 Answers
Change the Jumper To Master Or Slave.
CS Is cable Select, your computer may not support this Option.
If installing on a cable with a drive, already connected. i.e hard-disk. if the hard-disk is slave set the cd rom to master.
Enabling both channels, is the 2 individual slots on your motherboard. Primary And Secondary. Or IDE 1 And IDE 2.
This will solve your Problem.
Mike @ compurepair.
Posted on Feb 22, 2008
My hp pavilion does not see the dvd drive I just installed
Chaange the data cable if the it pata , the jumper select cs other wise fit tightly.if not wor again change it newly .If it is sata change newly or fit tightly.
Nov 21, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
Hp pavilion zv5000 no sound. vista OS.
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Aug 19, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
I have an HP pavilion pc that wont turn on
you prolly had the jumpers on the new dvd drive improperly set, you want them set to cable select for most cases.
if, on the top or bottom of the dvd drive, it does not have a diagram of which jumper is the master, slave or cable select (usually labeled, cs), then you will haver to look it up in the manual.
if you were connecting the drive to a ribbon cable that is shared with another drive, both drives on that cable must be set to cable select, or one must be set as master, and the other as slave. if there is another drive (optical or hard drive) on that cable, and it is set to the "master" position, the new drive will have to be set to "slave" OR both drives will have to be set to cable select. if you connected the optical drive (set to cable select) to the same cable as the computers primary hard drive (the drive which boots it) and the hard drive is set to master, then it may not boot, until both are set to cable select, or one is set master, and the other, slave.
the other possibility is that you have exceeded the capacity of your power supply, but that is highly unlikely.
Oct 09, 2009 | HP Hewlett Packard Pavilion Slimline...
Computer not recognizing any cd's
DEAR,
YOUR CD ROM DRIVER IS DELETED IN YOUR COMPUTER . SO YOU CAN REINSTALL THE DRIVER . IF DETECTED CD DRIVER , TO CREATE THE FOLLOWING STEP....
GO TO THE BIOS SET UP YOU CAN CHANGE SECOND BOOT DEVICE ( CD-ROM) .THEN SAVE . IF EVERYTHING IS OK .
YOU CAN CHANGE THE CD-ROM.
Mar 07, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Machine won't recognize CD-ROM after harddrive format
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Nov 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
Unable to burn cd or dvd
on the end cable connector should be master on middle connector should be slave or both on CS cable select.
Nov 02, 2007 | HP dvd740i DVD±RW Dual Layer Burner
KHypermedia (KHCRW522452) (20326452) CD-RW Burner Logo
137 people viewed this question
Top KHypermedia Computers & Internet Experts
David Payne
David Payne
Are you a KHypermedia Computer and Internet Expert? Answer questions, earn points and help others
