Question about HP Compaq ProLiant ML530 Server
BIOS SETTINGS how to enter in to bios settings
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Usually you can enter on your BIOS Settings by pressing F2 or F11 on some PCs. When the computer boots, before it enters into your operatng system, press F2 or F11. Please rate if this would help you.
Posted on Feb 04, 2010
Vostro 200 vos200
One possibility is a dead BIOS (CMOS) battery. If you open the case to expose the motherboard, searching you should find a flat silver battery, about the size of a quarter. On the surface will be a number, likely CR2032 (maybe CR2025). The current from this battery refreshes and maintains the volatile data in BIOS, such as date / time etc. If the battery died, the BIOS will return to factory default settings. In the event the system has been altered in some way (replaced hard drive, custom RAM with different voltage requirements...), default BIOS settings may block boot-up. How to test? Power up, enter BIOS, check time. If time/date are off, the battery has likely died. How to fix? The batteries are available many places (Radio Shack, Amazon.com, maybe Walmart.. ) for less than $1. Replacing the battery, powering up, entering & refreshing BIOS {AKA "setup"}, saving settings & exiting BIOS MAY trigger the system to boot, as BIOS is capable of self detecting settings for certain components.
{Note: replacing a dead battery first is recommended but is not technically required while testing. If plugged in, BIOS should retain settings between boots).
Depending on the BIOS and any hardware changes made "post-factory", booting MAY require determining and manually entering BIOS settings for non-factory components(e.g.: RAM voltage, timing, etc.). Custom BIOS settings and other complicated solutions are beyond the scope of this introductory "Quick Fix" solution.
Nov 05, 2013 | HP Compaq dc7100 PC Desktop
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
When i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
VAIO VGNFJ270 NEEDS PASSWORD!!! HELPPP
  • Restart your Sony Vaio computer.
  • Press the "F2" key to enter the BIOS.
  • Use the arrow keys to highlight the "Load BIOS Defaults" menu option. Select it by pressing "Enter."
  • Highlight "Load BIOS Defaults" again and hit "Enter." This will reset all of the settings of your Vaio's BIOS back to their original factory defaults. You can now select "Save Changes and Exit" to exit the BIOS.
  • Dec 09, 2010 | Sony VAIO VGN-FJ270/B Notebook
    Acer 5620 pressing f8 at start wont load bios either
    F8 is usually reserved for Windows Safe Mode. BIOS settings are usually found with by pressing ESC, Delete, or F2 on most system. Some times I run my finger along the entire row of function keys like a piano if it isn't specified which key works during boot up.
    Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
    Which keys let me enter my bios settings on my philphs MT1400 ?
    WHEN U START UR COMPUTER, THEN AT THE TIME OF BOOTING, PRESS DEL KEY CONTINUE, UNTILL UR COMPUTER ENTER IN BIOS SETTINGS, U WILL SEE A BLUE COLOR SCREEN, WHEN UR PC WILL ENTER IN BIOS SETTINGS.
    I HOPE U WILL GET THE SOLUTION.
    Nov 07, 2009 | Computers & Internet
    What is phoenix. My lap top doesn?t work he says press F2 to enter SETUP. When I press F2 he says enter SETUP. What?s that means.
    Phoenix, is the brand of BIOS installed on the system. BIOS = Basic In Out System and is the imbedded software (also known as Firmware) of the motherboard that coordinates the communication of the hardware (Motherboard, drives, video card etc) with the operating system (Windows). The SETUP refers to the parts of the BIOS that can be configured by the user. (You can turn components on or off, and change various settings or see what componets are installed in the system.)
    http://en.wikipedia.org/wiki/BIOS
    Oct 06, 2009 | Computers & Internet
    My dell inspiron 8000 display`s a small screen why?
    That is an option in the bios, you must enter the bios and change the settings manually. Enter the bios by pressing F2 while the computer boots. When in the bios change the screen settings to expanded.
    Jun 12, 2009 | Dell Latitude D620 Notebook
    Bios check sum error
    Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
    Dec 18, 2008 | Computers & Internet
    Unable to boot
    i have intel D101 motherboard and 2.8GHz processor, 512MB Ram but boot settings are disabled in bios
    and unable to enter into bios.
    Aug 09, 2008 | Intel D101GGC Motherboard
    HP Compaq ProLiant ML530 Server Logo
    1,765 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
