Question about Toshiba Satellite A75-S211 Notebook
Power adapter I bought a new power adapter and battery to try to solve this problem, but it didn't help. I will plug it in to charge, but if I turn it on, it looses connection.
  • BusterSFL Mar 29, 2008
    I am encountering the same problem. Does anyone have a solution?
These computers are notorious for this, the power plug, on the cpu, the power lead of these break easily, take it apart and resolder the connections, should be 100%, or take it in to a professional, about 100 bucks
Posted on May 07, 2008
    Genius:
  • 3,422 Answers
This is coolguy008. i am on a live chat session with you now please give me a reply so that i can fix your problem..
Posted on Feb 20, 2008
Battery not charging at all
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 15, 2013 | Acer Aspire One D255-1549 Atom N550...
I have a samsung r710 laptop which i have had for a few years. I started to have problems with the battery charge not lasting long which got worse until it wouldn't charge at all. The battery went to...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Samsung NP-R710 AC Adapter 60Watt 19V 3.15A
Replacement Samsung NP-R710 AC Adapter 90Watt 19V 4.74A
Nov 13, 2012 | Computers & Internet
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
Power problem
first dint buy (not original) adapters and replace the original adapter try to charg battery
Jun 22, 2010 | HP Compaq Motherboard
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
I had a GPU issue so i searched in google to find a solution and i found a solution it was needs to open the laptop , the motherboard the GPU problem solved now but there's a new problem that i didn't have...
I would check to make sure the AC adaptor connection on the motherboard was not damaged when you opened the pc. ( I have done that a few times.) I'm uncertain of what you have done to solve the problem. Since you have the new battery, again try to charge the battery. when it show the charge is complete, let the pc run until it goes off, when it does, keep powering your pc on until it will no longer power on. (You want to make sure the battery is completely drainned.) Once complete, try plugging the AC to your pc and monitor the charge. You may need to let the pc charge for at least 2 hours before powering the pc on.
Good Luck
C2Solutions
Aug 17, 2009 | HP Pavilion dv2000 Series Laptop Full...
Toshiba laptop wont turn on
Hi, you must remove the battery pack and connect with just the power adapter, and tries to turn on the computer if it operates properly and the battery problem solved
May 05, 2009 | Toshiba Satellite P105-S6104 Notebook
Hello June, This sounds pretty easy, I repair these cameras. It sounds like you have a problem with the adapter that plugs into the wall outlet. Remove the battery from the camera and plug the a/c adapter directly in to the camera and try to power on the camera,if it powers on then the problem is the dock,if it do not power on it is the a/c adapter.
Best Regards, Russell
Apr 27, 2009 | Kodak EasyShare DX7590 Digital Camera
Compaq evo n610c battery not charging
Hello All;
I used to have these same problems. I replace my BIOS battery, which I know was dead, because all settings get reset when I unplug the power and remove main battery. You might not have to replace it if its still good. Back to the main battery problem, You have a good change of solving this by going into BIOS, and under Tools there is a Battery Calibration option. Do the calibration for the main battery and-or other optional batteries attach and it will most likely solve the problems. This calibration process will take a long time; 1-charge, 2-discharge, 3-recharge, so leave it over night or however.
There was a mention of updating BIOS. This could solve the problem too, because BIOS controls the charging unit. Also, make sure you have Compaq Power Management install on your OS, (download at hp.com).
One note: it will not charge if the battery is about 93% or higher. 93 is not exact, but close to 90%. so test by discharging to below 90% and it will start charging again.
If anyone tries this, leave a post of your success or failure.
Nov 20, 2007 | HP Compaq Evo n610c Notebook
Toshiba Satellite A75-S211 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
