Question about Philips Televison & Video
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust contrast, brightness but nothing works. Any ideas?
  • jandkwroblew Feb 04, 2010
    I have OSRAM69374 as replacement. It has just P22 next to it. If this is incorrect do you correct model #? Thanks Jeff
    Scholar:
  • 130 Answers
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Posted on Feb 04, 2010
  • Eddie
    Eddie Feb 04, 2010
    An Osram should be compatible, but the best lamp for your TV is a Philips UHP lamp at 100/120W. You should either get a replacement, or make sure it's not your ballast that's going out on you. I can't stress the importance of a Philips lamp over Osram though.
How can I tell if my lamp IS the issue? My 50PL/9126D/37 Philips tv pretty much looks like black & white BUT the picture keeps rapidly flickering random colors in my picture. Yes, the "Lamp...
Hello
If the lamp replacement light comes on, surely there will be issue with the lamps; and should be replaced. But the flikereing of colurs will have an other probelm with video card. Chroma section may be some fault with it. Just check the antena if your are using and seeing on-air programme. If you are using cable, check the socket ottection at the backe of the tv for firmness. If connections have some loose contact, or not well tight up, colour flikering will occur. If all the connections are OK and just replace the lamps and see the effect. If this does not help you , replace the chroma card. Consult nearest philips service center for replacement. For lams alos, replace it with original ones from Philips. OK.
Jul 24, 2011 | Philips 50PL9126D/37B 50" DLP TV
I own a 50PL9126D/37 50 in DLP TV I bought used and the picture is dark so I took it apart because I was told it could be dusty or could be the lamp. After I cleaned the inside screen VERY carefully with a...
Dlp tvs have dark pictures,first thing u must be alway change the tv projection lamp.Specially,if u bought used,because u don't know how long the projection lamp been inside that tv already.After u change the projection lamp,still have problems or hear alots of clickings sound too.This problems the board call the Ballast board is it dead too.This Ballast board only job are just to ignite the tv projection lamp only.
Jun 08, 2011 | Philips 50PL9126D/37B 50" DLP TV
Philips TV dim... could this be a bulb?
The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes,than the tv projection lamp it is the problems and require the tv projection lamp replacement.
May 25, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Need a lamp in my philips 50PL9126D/37 TV
Unplug unit and remove lower back panel should be 2 screws on each side and a few across the middle. Pull panel back and you should see a black box with metal folding handle. Remove the two left screws and pull out.
Mar 28, 2010 | Philips 50PL9126D/37B 50" DLP TV
I have a 50'' Philips tv. When I turn it on the picture comes on fine, within a matter of minutes the picture goes out and this red light comes on highlighting a tiny picture of a light bulb on the ''on...
Sounds like your lamp is bad. I think this is the set where you have to take the whole back off to replace the lamp. Once you take the back off, its on the left hand side.
Dec 02, 2009 | Philips 50PL9126D/37B 50" DLP TV
Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Oct 08, 2009 | Philips Televison & Video
Televison & Video Logo
191 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
