Question about U-Line Icemaker
My icemaker shut down the red light on the circuit
My ice maker shut down the red light on the circuit board is on but I have no power to the unit?
  • jjbuilds Feb 04, 2010
    I have power to the board however when I plug the connector back in the green light comes on and I hear a clicking sound then the light goes off,
    Jim
  • 10,515 Answers
You need to Check the Transformer and Voltage to Control Board at Line and Neutral.If you have Voltage there, you need a New Control Board. Let me know, the Make and Model as well so that i could further assist you testing all these Components.
On Most Models, once you pull out the rear cover off, you could have an access to Pump. The Icemaker plugs into and outlet on the pump and then the pump plugs into your outlet. If the Pump is Bad, it would kill the power to Ice Maker.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 04, 2010
  • taran_2005
    taran_2005 Feb 04, 2010
    Thanks for your response!!
    That's the reason i mention that we need to Test the Components. You could tell me the Make and Model of the Icemaker so that i could try to Search the Service Manual..Have you checked the Location of PUMP?
    Do you have tools like Voltmeter, Repair Experience to Fix this or Would you like to Call a tech to Fix this.
    Hope i helped you.
    Thanks
  • taran_2005
    You could try to Keep to Unplugged for few minutes, say 30 minutes and then Turn ON the Machine and Check if that could Fix this.
    Hope i helped you.
    Thanks
PFSF5RKZC Icemaker stopped making ice.
Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
Apr 03, 2014 | GE Refrigerators
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
My whirlpool side by side has an infra-red icemaker control across the opening just bellow the icemaker in freezer compartment, what does this do and what symptom if it were faulty? The icemaker makes ice...
The mechanical shutoff arm on the older ice
makers has been replaced with an electronic
ice level control system. This system is located
on either side of the freezer liner and utilizes
infrared light technology to sense the level of
ice in the door-mounted ice container.
Diagnostic and pretty pictures are HERE
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
My clr 2060 ice maker is not doing anything,their is no ice in the storage bin. opened up ice maker and cleaned the condenser coils. Found red light on board lit, with a slow steady blinking green light
HI
It sounds like you have a drain issue. You can do a test with the unit on open the panel with the board and remove the 2 pink leads and make a jumper for those terminals. If the unit comes on 3 min fill then circulating pump and compressor and fan come on then you know you either have a kink in the drain line or a bad pump. If your unit doesnt have a drain pump then the pink lines could be open and it will turn the unit off too.
Sep 13, 2009 | U-Line Icemaker
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Freezer stopped making ice cubes
If temps are ok, then be sure you ice ben is in properly. if that checks ok, check for water/ice in ice maker mold....Try turning unit off and then on in 5mins. this resets the ice maker...if that doesnt work, need to check for power at icemaker. good power means bad icemaker. no power means bad board.(usually) Would suggest you to have a cert GE Sercvice company look at it if no power to ice maker.
Jun 09, 2009 | GE GSH25JFR Side by Side Refrigerator
Starts to make ice, but goies in reverse cycle before finish
OK. Forget the board. what you hear is the pump running when the unit is off. It sounds like a drain is kinked and the pump is shutting it down for safety.Also when this unit starts it will dump early for a couple of cycles before the ice gets normal size. Run the icemaker and unplug the pump in your water trough to make sure it has a frost pattern all the way thru.(takes 5 min)If not it could be a leak it the sealed system. Remember when you adjust the setting on the board this will take 5 cycles before you see any changes. And 24 hours for more consistant ice.
Mar 26, 2009 | U-Line Icemaker
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
U-Line Icemaker Logo
53 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
