Comp wont start up
  1. Pressed esc after start up screen(which does not load up properly)
  2. It says system BIOS shadowed, and Video BIOS shadowed
  3. Press F2 for set up and thats it
  • Anonymous Jun 27, 2008
    ACER Aspire 3690
    System BIOS Version V3.24
    System BIOS shadowed
    Video BIOS shadowed
  • mnmnmn Sep 15, 2008
    I can not enter the bios! system directly boots to os! What shall I do?
  • 813 Answers
Hey man press f2 Go in setup then after go in boot manu & select in a fristboot device in hard drive if hard dive not aaper in ur laptop then remove & reple it try to detact your hard drive
or
press f2 go in setup restote as defolt satting then after strat ur pc
Posted on Feb 20, 2008
    President:
  • 4,402 Answers
It sounds like it not seeing you hard drive, remove battery and ac power and then make sure everything external is removed and then power it back up, if it doesn't come up my guess would be bad hard drive.
good luck
please mark the post with a fixya
Solution system bios shadowed video bios
To "shadow" is to use a small amount of the RAM to hold a copy of the system-BIOS and the video-BIOS areas. This usually speeds-up the computer, i.e., use RAM that is faster than the RAM on the motherboard.
Nov 04, 2013 | Compaq Computers & Internet
How to exit safe mode
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Apr 30, 2013 | E-Machines Computers & Internet
The boot order was saved in the bios and now when i press f2 it wont let me in
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Apr 17, 2013 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Compaq stuck in utility mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 14, 2013 | Compaq Armada 1750 Notebook
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 05, 2013 | Dell Latitude D800 Notebook
My toshiba c850 is in flight mode, how do i get out of this?
Feb 04, 2013 | Toshiba Satellite Computers & Internet
CD Drive will not allow boot
Change the boot order
Feb 03, 2013 | Computers & Internet
Proper booting up, what needed to type f4 or f2
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
Dec 01, 2012 | Microsoft Windows XP Professional With...
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
My laptop says entering set up but does not enter. it says enter F2 for set up. when I press F2 key it says entering set up but nothing happens. When I switch on the laptop if I press the ESC key it says...
Nice way of experimenting , but if you want to continue working on your machine without errors, just load the default settings and save them while you exit. Also make sure you have the battery replaced on the motherboard.
Nov 15, 2009 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
430 people viewed this question
Alun Cox
David Payne
David Payne
