Question about Globe Stellanova Series Magnetic Levitating
Magnetic floating globe
Globe does't levitate anymore, what's the solution?
4 Suggested Answers
momsjustknow
  • 135 Answers
SOURCE: Fascinations Blue Globe With Silver Base Problem:
http://www.fascinations.com/contact.htm I tried to look up FAQs or troubleshooting for you or maybe a product manual, but unfortunately the website for the distributor of these globes has a fill in the blank request form and you will need to fill it out yourself.
Hopefully they will have an easy fix for you.
Good Luck! from Moms Just Know
Posted on Oct 29, 2008
micromend
  • 748 Answers
SOURCE: can't get the globe to levitate
Hi
This system works because of magnetic attraction. One of the magnets no longer has a good charge. Magnets do have a shelf life.
Posted on Jun 03, 2010
SOURCE: Globe does not float.
take away the globe from the top magnet, then use your two hands to hold the globe, gradually close to the top magnet, pls note the floating distance is about 2cm, when you feel the balance, release your hands gently, finally, you succeed in floating it well. Congratulations!
Posted on Jan 08, 2011
Saeco Magic problem. The magnet rises when I fill the water tank off the machine but, it drops as soon as I make a cup of coffee. To clear, I have to remove the tank and reset the machine. Any help?
hi,
what do you mean by "it drops" ? If it doesn't float anymore, you have to replace it. Remove the top cover of the small tube where the magnet floats, replace the floating magnet and replace the cover.
If the cover doesn't seat properly, glue it with a drop of silicone so you can remove it next time.
If the magnet floats but is not recognized by the inside detector (the small white block you can see inside the machine, in front of the magnet), it is probably because the magnetism has fainted with time. Replace it with a new one.
Hope that helps.
M.
May 14, 2016 | Saeco Magic Comfort Plus Espresso Machine
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Can't get the globe to levitate
Hi
Jun 01, 2010 | Fascinations Blue Globe With Silver Base
Apr 24, 2010 | Globe Stellanova Series Magnetic...
Could you float a ball by covering it with magnets with north facing outward and then a circle of magnets north facing up with one with south facing up in the center of the circle?
not sure, but sounds like an interesting project
This link is a great source for alternative energy needs and supplies,the best deals I have found on Neodymium magnets and solar/wind energy projects for your experiments. let us know how things work out.
http://www.magnet4less.com/index.php?ref=252
Oct 30, 2009 | Dowling Magnets Magnet Levitation Set
The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Apr 08, 2009 | Saeco Incanto Classic Espresso Machine
Oct 28, 2008 | Fascinations Blue Globe With Silver Base
Need quiet repl. fan (Sunon 50x50x15mm)
HEY BUDDY...............
U DONT HAVE ANY PROBLEM...IF U R CPU IS PROPERLY  U NEED NOT TO BURRY.ITS OK
AND FAN NOICE DOESNOT MATTER MAN.....MY PC  ALSO HAVE 3 FANS AND CREAT SO MUCH SOUND..............
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Sunon 50x50x15mm DC 12V Magnetic...
Globe Stellanova Series Magnetic Levitating Logo
324 people viewed this question
Top Globe Toys Experts
ray gallant
Are you a Globe Toy Expert? Answer questions, earn points and help others
