Question about Honeywell Dual-Action Air Circulator Fan - Black
Circulating heat which way do you turn the fans to circulate heat in the winter?
  • 10,865 Answers
Hello. In the winter you do not want the air coming directly at you, instead you want it to be pulled away from you and mixed with the other air in the room.
Regards, Joe
PS kindly rate my answer. thank you.
Posted on Feb 04, 2010
Why still over heating, replaced all last year, water pump, stat, flushed rad
Possible causes....Poor internal circulation or heat exchange due to blockage or corrosion/scale.
Likely causes.... Electric rad fan (if so equipped) failing to turn on, or broken fan belt (if so equipped), or broken, damaged or missing fan blades, or blockage of air into radiator (lots of bug guts, plastic, paper, debris in general), or damage to radiator itself. (cooling fins are mostly bent over restricting air flow or circulation, scale build up inside of the radiator...not always "flushable" preventing good heat exchange.
One or some of these maybe causing your grief. Good Luck.
Feb 25, 2016 | Cars & Trucks
Does the fan operation bring in outside air or just circulate air inside the space?
The fan is the same one use to circulate air thru the heat or A/C coil. When set to auto, the fan only comes on when the thermostat senses that it needs to add heat or cooling to the space. When set to on, the fan runs regardless of whether or not it is adding heat or cooling on not.
Mar 13, 2015 | Heating & Cooling
When I turn on the heat this winter i found that I lose my heat when i stop at a light or running in idle.The heat works the best when i have the control on low fan, but it takes for ever to heat up. ...
When you hit your gas, the volume increases in your radiatior and the hot water circulates. When you are low on antifreeze or coolant, it doesn't circulate during idle. Check your coolant levels and make sure the thermostat is opening when the engine heats up. Do this by running the engine with the radiator cap off. When it heats to 190 degrees, you should see the level drop, start to steam and start to move. Don't forget to rate me high please.
Jan 21, 2011 | 2000 Ford Focus
Should ceiling fans work "forward" or "backward"
During the winter you want the fan to blow downward so that the heat that collects at the ceiling is circulated,
Nov 20, 2010 | Universal Remote Control Hampton Bay...
Help- when heater gets to room temp. the circulating fan stops, but fire remains in combustion chamber and the blower motor or exhaust fan continues to run for hours. Toyostive laser 56MH thanks Jim...
Sir,
If there was a flame in the burner and no circulating fan running the stove would over heat in less than 5 minutes. It would show an EE 6 message. Are you sure there is a flame in the pot? The stove does have a safety feature that allows the combustion fan and circulating fan to run continuously in certain cases. This is a rather extreme case. In any event the circulating fan would be running at the same time the combustion fan was on. To get out of that mode turn the stove off and on again. Now you should be able to restart normally. Keep us posted,
Thanks,
Tom
Oct 21, 2010 | Rinnai Toyostove Direct Vent Heater:...
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
My upper radiater hose blew n engine over heated. I installed a new hose n replaced fluids. engine overheated again. did not blow though
check the serpentine belt for slipping, the clutch fan, the thermostat(might be stuck closed) or maybe it is a circulation issue, you can check the radiator and radiator cap for defects and sediment buildup.
you might be able to confirm circulation problem if you turn heat on and it doesn't overheat.
Apr 30, 2009 | 2000 Dodge Durango
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Over Heating
use a/c to engage cooling fans and keep engine cool til you locate the fan/circulation problem....
cooling fan temp switch is a likely suspect also the thermostat for general circulation problems .. be sure to flush and fill when servicing thermostat .. belts hoses water pump round out suspects here..... without any more info all i can tell you
Sep 05, 2008 | 1990 Nissan Pulsar
Honeywell Dual-Action Air Circulator Fan - Black Logo
126 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
