Question about Motorola Mobility RAZR V3i Cellular Phone
Itune sound itune mp3 sound is very low
First of all convert the mp3 into a wave file and then increase the volume of the sound .then when the sound is of desired level ,convert it back into mp3 and hear it on ur razr.
Posted on Feb 25, 2008
Somebody copy songs to my ipod nano /and the songs appear on the compter when you plug it in but it willnot down load on my ipod nano
Sounds like they did not use a iTunes to copy the songs to the iPod.
iPods/Phones/Pads, etc require iTunes to create a sort of file that tells the iPod where the music file is located at on the mp3 player.
So if they just plugged it in via usb and drag and dropped mp3 files over then there is no file to tell the iPod where they are.
So you'll need to drag those music files off of your iPod back onto a computer and then use iTunes to import the songs into iTunes and sync your iTunes library to your iPod.
Mar 02, 2011 | Apple iPod nano MP3 Player
My ipod sounds distorted, even at low volume, with the EQ turned off
you can update your ipod in iTunes. then it will back to normal
Feb 20, 2011 | Audio Players & Recorders
IPod 8 gen . the sound is too low and the wheel
Try restoring the unit through itunes and reloading all the music back on the unit. If the problem still persist, did you download your music from itunes/have itunes convert the songs before putting them on there. If you got your songs from a third party (anyone besides itunes), the songs could be a bad quality. Sometimes the songs will actually not be that loud. If all of your songs are low and you cant hear them, and the restore does not work, your headphone jack/motherboard is most like not working. Contact Apple to see if your unit is under warranty with this site: https://selfsolve.apple.com/GetWarranty.do
Your serial number can be found on the back of the unit toward the bottom.
If you have any other questions feel free to contact www.wiredextreme.com.
Nov 13, 2009 | Apple iPod nano
After installing Itunes on my computer, have noticed my computer has slowed right down, any theory's on this ? Also music installed on my new ipod from My Music files sounds very tinny. Has anyone else...
iTunes is horrible, horrible audio software.
It is likely your computer has slowed down because by its default settings, iTunes 'helps' you by reorganizing all your music into an incomprehensible directory structure only apple products can use. It will also re-encode your .mp3 files into apple's format to make it even less likely you will listen to your music on a competitor mp3 product.
For best results with your ipod, review all your iTunes settings. Tell iTunes:
  1. to manually manage the music on your ipod
  2. not to reorganize your library
  3. not to reencode your music files
  4. to encode new music files in .mp3 format, joint stereo, at 96K or 128K sampling frequency.
I hope that helps.
Oct 24, 2009 | Apple iPod nano
Very low battery
It sounds perfectly fine. :P
The only problem is that the battery is very low! You have to wait for it to charge so that it can come up onto your computer, silly. Just let it charge for a few minutes and then I'm sure it will work fine. If there is still a huge problem with it, maybe you should call apple and see what they have to say about it.
Jun 20, 2009 | Apple iPod MA446LL/A MP3 Player
I plugged my ipod into the computer and it says file missing
In iTunes, turn off automatic sync. Sync your songs manually.
Mar 20, 2009 | Apple iPod MA446LL/A MP3 Player
Hi my ipod it stuck on low
It sounds as though you have a bad battery, need to get it replaced. iTunes will not recognize it until it boots up and connects to your computer. As long as the battery itself remains low, your iPod will not boot up to be seen.
Jul 06, 2008 | Apple iPod MA446LL/A MP3 Player
Sansa e260
Zune can only do unprotected content from ITunes, and i don't know how much is unprotected
iTunes only works with iPod generally
stick with Sansa? if you posted this is the right section, your Sansa should not be compatible with iTunes
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
Wont Sync with Itunes
Sounds like a repair may be in order. Sometime you can simply have to restart your computer and open just iTunes (no other programs running) and then iTunes will see the iPod. If your computer can 'see' the iPod, then iTunes should see it as well.
Rick
EverGreenElectronics
Mar 07, 2008 | Apple iPod MA446LL/A MP3 Player
3g ipod nano
Check the headphones. They might be burnt up. Test it out with another set. If that doesn't work, you can change the settings of the ipod while connected to itunes. Go to options, settings, and change the volume max to higher.
Nov 06, 2007 | Apple iPod nano
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
