Question about Mitsubishi Televison & Video
Wd-52526 projection bulb has been replace but
Wd-52526 projection bulb has been replace twice but screen is still very dark I have done system reset. any other suggestions
    Scholar:
  • 130 Answers
If may be a power supply or ballast issue. The ballast feeds power into the lamp and it may not have enough power, or may not be able to FEED enough power into the lamp after it ignites it. That would account for the dim picture.
Posted on Feb 04, 2010
I have a Mitsubishi WD-Y57 1080P. I knew that my bulb was about to go because it was getting dim. I have replaced the bulb twice in the past. This time however, the day before it totally died, the...
Is your remote control possibly bad? Is it set to other than TV mode? Batteries? Nothing to do with lamp, but TV must turn all the way on for remote to operate anything besides power on/off. --Remote is a function of TV microprocessor.
May 25, 2014 | Mitsubishi WD-Y57 57" Projection HDTV
I have a Mitsubishi projection tv model wd-52526. The tv has sound but no picture. It will display channels or devices Is there a simple fix to this?
no picture or a big black box covering the picture. If it is a big box covering the picture then you need to turn off closed captioning.
Mar 11, 2013 | Mitsubishi WD-52526 LCD TV
Replace tv lamp but the replacement light is still on how do I turn it off
Hello
Reset the lamp hours through the TV setup menu each time you replace the lamp cartridge. Otherwise,
the lamp warning message will reappear sooner than necessary.
After you change the lamp cartridge, you must reset the lamp
reminder through the TV Setup menu
Go to the setup menu, there you can see the reset proceedings with illustration. OK.
May 12, 2011 | Mitsubishi WD-52526 LCD TV
Just bought a Mitsubishi WD-52526. With Brightness, Color, Sharpness, Contrast, Everything Video turned all the way up the Screen is still very dim. Is this a lamp issue?
It could be. Do you know if the previous owner ever changed the bulb? If not you may have to replace it. The bulb usually costs around 160ish. I would try it and see if it helps the brightness.
May 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Put in new blub and heard a zapping sound is bulb bad or tv?
Check the bulb is not damaged and is inserted fully into the socket. The bulb needs several thousand volts to ignite which would be the sparking noise you heard if not connected properly.
Mar 08, 2011 | Mitsubishi WD-52526 LCD TV
Reset to get image
Try a system reset to clear the eeprom. Menu 2470 to get to the service menu, then immediately press enter on the remote. Goodluck.
Jul 05, 2010 | Mitsubishi WD-52526 LCD TV
WD 52526 I need a user manuel to install the lamp
Google to this websitie Encompass Parts Distrubtion
1-800-638-3328
Apr 14, 2010 | Mitsubishi WD-52526 LCD TV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
208 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
