Question about Nvidia GeForce 7200 Graphic Card
Gateway 831GM Desktop does not support VGA CARD
I have a gateway 831GM desktop (bought it in 2005) So i decided to upgrade the video card with a GeForce 7200 GS (Nvidia product) I placed it in the PCI express x16 slot, secured and fastened. So when i went to turn it on I placed the CD in, and i get a message saying "Sorry but we do not support your VGA card" I dont know what to do? should i call gateway support? or Nvida?? Or is there another alternative? Thanks
  • 4 more comments
  • Jorge V Feb 04, 2010
    Yes, this is an add-on...meaning when i opened up the desktop to there was an empty slot waiting for my Geforce. Ok so that means i have to disable the factory VGA card then...how do you get into setup? and disable??
  • Jorge V Feb 05, 2010
    Do i have to plug the monitor cable to the 7200 GS? because it wont fit...so that means ih ave to go to the computer store and find the right cable for it? or can i buy an adapter?
    Ok well I put plugged in the cable to the Geforce 7200 GS D-sub monitor and the plugged the other sided to my Samsung Syncmaster 2033 (50000:1 dynamic contrast) monitor. And as soon as i turn on the computer, the monitor turns on but i have no picture, there is a analog vs digital function but i still cant get a picture. OR before i do that.. do I first hit the f2 button to go into the BIOs setup? See i did go and i couldnt find enable primary video card.. and do i still have to go to the store and buy the white flat panel display cable?? thanks again
    nevermind the last message..I got it working :) Alls i had to do was reset the computer and it loaded up just fine and it recognized the new software and downloaded whatever it needed to do..and alls i had to do was fix the resolution up. But the only thing im pondering is if i have to go back to the F2 setup when the computer is booting??
  • Jorge V Feb 07, 2010
    Yes I will still buy that DVI cable. Thanks a million!!! Beers are on me!
    The solution was extremely helpful, homedesigner guided me through the problem step by step, and the most importantly is i learned alot from this problem turned into a successful solution, Thanks again homedesigner!!
  • 583 Answers
Did you replace a video card or did you add this one. Was the original video card integrated? If it was, you need to go into setup during computer startup and disable the VGA card that is embedded in the motherboard. If you replaced a video card, you need to go into add/remove programs in the control panel and uninstall all references to the old card.
Posted on Feb 04, 2010
  • 2 more comments
  • Mark Tidwell
    Mark Tidwell Feb 04, 2010
    When the computer is booting up, press either F1 or F2 at one second intervals to enter the Setup utility. Once in there, you will look for entries like integrated components, video, or the like. Find the one to disable the integrated video. Press the appropriate key (usually F10) to save the changes and reboot.
  • Mark Tidwell
    Let me know how it all worked out. Thanks for the opportunity to help you out.
  • Mark Tidwell
    Mark Tidwell Feb 05, 2010
    You can get an adapter from the DVI connector to the VGA connector on your monitor. Depending on the monitor, it may have the whtie DVI connection on the back as well. If it does, go to the store and get a DVI cable as you'll like the result you get on the monitor much better (Digital vs. Analog).
  • Mark Tidwell
    If it is now working, you shouldn't have to go back into setup. Some of the Gateway's have an automatic detection and the ability to select is not in the BIOS, but since it seemed it refused to work, I figured it was a BIOS setting. I'm glad you got it working though and glad I could be of help. You may still want to get the DVI cable to connect to your monitor in the future sometime, but you can do that at any time.
Upgrade video card
check with gateway support to make sure your warranty is ok, for you change card, then goto motherboard manufacturer see if the card is supported
Jan 24, 2014 | Gateway SX2803-UB20P Desktop PDC 3.2GHz...
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Sound driver for gateway 831gm windows-7
If you are having problems with the driver, a standard reinstall should be enough to fix it. Navigate to Start->Device Manager and click on "Sound, Video, and Game Controllers". Right click on your sound device and click "Update Device Drivers".
Apr 16, 2012 | Gateway 831GM PC Desktop
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
HI I AM HAVING SOME TROBLE I BOUGHT SIMS 3 AND CANT PLAY
Get a video card as was recommended by EA. You have a PCI-E slot (also known as PCI-X or PCI-Express). You should be able to find one in the $80 range at any Best Buy or Fry's that will work.
Jun 29, 2009 | Gateway 831GM PC Desktop
Video card upgrade for Gateway GT4024
Try looking up for Updated drivers at Gateway for your Computer. Also find out what video it's using (ie. NVidia, Radeon, etc.) Many times the Video Card maker will have the latest updates for video cards before they get to the computer maker.
Jun 10, 2009 | Gateway GT4024 PC Desktop
Upgrade video card
Any of the cards here are suitabl,e with almost all under $100 and are all PCI Express x 16
Your mobo is not suitable for the PCI X 2.0
Remember the amount of memory on the video card comes from your available ram - so you need to consider this when buying if you dont have much ram.
If you need more help deciding let me know
Apr 19, 2009 | Gateway GT5012 PC Desktop
I want to upgrade to a new video card
You can put new Video card accordingly. Just buy an good Video card which have inbuilt memory and that support your operating system. There are loads of Video card available in the market.
Dec 26, 2008 | Gateway GX7018E PC Desktop
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
Nvidia GeForce 7200 Graphic Card Logo
334 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
