My computer turns on with all of the lights and fans running but my computer screen power light immediately turns yellow, indicating it's in some power save mode or that my computer is just broken. Can you help?
  • 6,487 Answers
This can be a problem with the video part of your computer, first thing to do here is to disconnect and reconnect your monitor from your computer tower and then restart the computer and check if its already working. But if still not working you can try first a different monitor because sometimes the problem here is the monitor and if still not working this is already a problem with your Video card and may need replacement.
Posted on Feb 04, 2010
When i push the power on the fans start running and immediately turn off. power is on
1) normally the pc has software diagnostic installed by the company.
RUN the software diagnostic.
2) otherwise you must open the computer and test a) voltage a the FAN coming from power supply b)if there voltage at the FAN is faulty, if NOT the problem will be in the power supply section.
God bless you
Oct 02, 2012 | Fujitsu Siemens SCENIC E600 PC Desktop
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
May 23, 2009 | HP Compaq Presario SR1420nx...
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
My Dell Monitor isn't working....yellow light?
A yellow light indicates no signal input. Test it on another machine.
Feb 16, 2008 | Computers & Internet
k24674
