Question about Garmin nuvi 205 GPS Receiver
Voice does not work. Have reset to defaults on numerous occassions, unit works, but no voice.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Do any of the sounds work?is it muted?
Posted on Feb 05, 2010
Unable to make calls using voice commands
Try by reseting your Headset device following this steps.
How do reset the H19txt to factory default
You will need to re pair the Headset with the phone.
Jun 30, 2014 | Motorola Mobility H19txt Universal...
Zebra 430T cannot reset to factory defaults
try with wwwseagullscientific.com drivers, this driver have the option to resset printer to factory default.
Mar 26, 2014 | Zebra Office Equipment & Supplies
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
How to reset the password for a Lucent Partner 18 phone system. The product is a Lucent Partner Phone system
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done. Your password will be the defaulted to1234.
Apr 17, 2010 | Lands Phones
My Garmin street pilot c550 has lost its voice, how do I get it back.
I am going to make some assumptions here. First, that the unit was working properly, giving voice directions, and now is not doing so. Second, that the volume wheel on the right side of the unit is set all the way up and you are not hearing any voice directions.
If those assumptions are correct, when you turn the unit on, press the wrench button at the bottom of the screen. Next, press the down arrow on the bottom right of the screen. Now press the "Volume" button. Make sure "Navigation" is at the level you desire (100% works well for me).
Again from the main screen, press the button marked "Locale." Next to the lip icon, make sure the correct voice (whichever you desire) is selected.
If this does not help, try resetting the unit. Remove the faceplate (there is an indentation under the top) and press the reset button on the right side of the unit. If this does not work, you can try a Master Reset, but be aware: IT WILL ERASE ALL OF YOUR FAVORITES. To do a Master Reset, press and hold the bottom right of the screen while pressing the power button. Release both buttons when the unit resets. Let me know if this helps.
Feb 23, 2010 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi 265w voice command stopped working. Any suggestion on what to check?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Nov 15, 2009 | Garmin Nuvi 265W GPS Receiver
Help!! Volume not working!!
  3. Touch Settings
  4. Touch Language
  6. Touch Yes
Nov 02, 2009 | Garmin nuvi 260W GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Howdy I have one of them 1st I phones works great except when I try and retrieve recent calls or voice mail it stays on favorites? Got me ain't been that long ago I was still using 8 track's. Electronic's...
I cannot understand what recent calls or voice mail has got to do with favorites.
If the voice mail is not working, then the voice mail settings may be wrong.
If the call list is not working, then do a reset to factory default from phone settings menu.
Oct 14, 2008 | Cell Phones
Voice won't work
Have you dtried reseting the GPS. Turn Off unit, take out SD card, at the back of the unit there is a tiny reset button push this with a end of a paperclip and then turn back on and re input the SD card this should return your voice.
Dec 13, 2007 | Tomtom GO 510 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
