Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
    President:
  • 3,197 Answers
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Posted on Feb 04, 2010
Testimonial: "Great answer, complete with part number to correct problem. Thanks!!!"
    Problem Solver:
  • 16 Answers
Complete repair instructions for this gear with huge pictures at:
http://dl.dropbox.com/u/1347192/lifter/liftmaster_repair.html
Posted on Feb 11, 2010
I have a Sears Craftsman garage opener. The garage door motor runs but the chain will not move.
Posted on Feb 12, 2010
M otor hums but door does not open
If the motor is running and the chain or belt isn't moving, you have a broken gear in the opener.
Mar 26, 2014 | Sears Craftsman LiftMaster Chamberlain...
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
My chamberlain whisper drive, 3/4 hp, motor hums with 5 flashes. Door works o.k.
Something in the drive is jammed preventing the motor from spinning. Correct the problem lest you will burn out the motor if allowed to hum and overheat.
Oct 12, 2013 | Chamberlain 3/4-HP Power Drive Chain Drive...
Door will not move up or down,the drive motor just hums.
On the inside of the motor box, check to make sure the chain has not come off the gear.
Apr 05, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster door opener, motor hums but chain and door does not move. Any ideas? Thanks
If the motor is running but the chain isn't moving you have a stripped drive gear. Remove the cover from the motor unit and check. It should be obvious.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster - motor hums, doesn't turn. Removed
My neighbor guy, who knows a lot about stuff, told me to get a new one.
Good solution.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor clicks but will not open door
motor is over heated shut down unplug 30 min
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
25 yr+ old Sears opener runs past lower limit
Update: I remembered that I had a problem with the door reversing too much a while back. It was chattering in the tracks and I could not fix it with lubrication and changing spring tension. So I dialed up the down reversing force. This contributed to the jam-up I had when the lower limit was ignored. If I had a lighter force, it may have at least reversed.
After futzing with it I left it alone for several hours. The motor would hum every few minutes. I was considering cutting power to it overnight. I pressed the remote one more time and the motor ran normally to a limit and stopped. I tested it a few times then reconnected the chain and door. Seems fine now. I suspect an intermitten logic board problem. I'll try lightening up the down force and using it for a while.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,184 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
