Printer install how to connect printer to pc
  • 2 more comments
  • krystal215 Feb 20, 2008
    lexmarkx2350 all in one prnter / usb cord / acer aspir pc (w/printer port different plug)/bought used,nodisc.works alone,cant connect to pc.-krystal15
  • krystal215 Feb 21, 2008
    dude....the damn usb cord to the printer is for a usb port.the printer port "plug "is a parallel port
    thanks.i guess its a driver problem or my haunted computer
  • Anonymous Nov 18, 2008
    where is the other hole to plug printer in
  • 813 Answers
1 u have tell us which type u have printer is its usb or parllal if u have parall port connant in behind in ur pc
Posted on Feb 20, 2008
    Genius:
  • 1,011 Answers
Hello sir,
What type of printer u have?.. First u have the Installation Cd of printer driver. U install the driver cd. ( If u don't have cd Send details Printer name, code no. etc...) U must plug to the backside of pc with the printer usb wire. ok. U printer has 2 two outputs. one is power cable and another one is to system cable. U have plug the system cable to back side of the pc. there is a hole of usb port. just plug it. ok
Thanks
Don't forget to comment...
Good Luck
  • 4,102 Answers
Hi this should be easy to do get the printer and plug the lead into the slot on back of printer then plug the other end into your computer their should only be one place it will fit in back of computer plug the lead in their might be picture of printer on back of computer it will be small and near a printer port.
The port in back of your computer is about 2 inches long or about 5 or 6 cm then plug the lead coming from printer into the port.
Now plug printer in and swtch on then switch computer on.
Now once your computer has started up you might get message new hardware found or start hardware wizard if you have disk that came with printer put this in your comp and follow instructions if you dont have disk let me know then i will talk you through the process let me know if your having problems ill be glad to help ok speak soon good luck but you should have no problems as its all plug and play and should set itself up.
If your printer is using usb port and not printer port then it will need plugging into any usb port on either the front of computer or back if you are unsure then let me know ok ill gladly help you ok
  • 1 more comment
  • paul proctor Feb 21, 2008
    Hi do you have usb ports on the front or back of your comp you usually have two but might be on front near cd drive ill have a look at your model and tell you anyway it should only fit into one of these due to the size plug it in with printer on then in bottom right hand corner you should have a usb screen pop up this will allow you to install the software from the net if you have no disk.
    Failing this if your usb port is not recognised then you need to plug printer into usb port then goto controll panel then goto on left hand side select classic view, now select add ahrdware devices this will then scan your comp for any hardware attatched to your comp.
    When the scan is finished scroll down the list untill you see either usb port or the make of printer then click this then install it will ask if you have disk dont check this box if you dont have disk then let the computer search the net for correct software it should locate it for you then install this and your printert should now work.
    Usb port could be on back but ill check and come back to you ok.
    If your computer dont find correct software then use search engine and type in software for then give make and model.
    let me know if you have any problems ok
    If the printer works of usb port then plug the printer into usb port on your computer it should then pick the printer up as usb devices are all plug and play and require little setting up but find any usb port on your computer you should have at least two put in in either one on front or back then you should see it in bottom right hand corner of screen let me know once you get this far. Also if a usb port dont work then try another if niether work then leave printer plugged into usb port then use add hardware wizard to install the usb drivers ok if you get stuck let me know ill be back online in couple of hours but hopefully you should be able to follow what i tell you let me know ok speak soon
    If you need help finding drivers let me know wether its the usb port drivers or the printer software you need the usb ones you should find by letting your computer scan the net for drivers just give us a shout if you need to ok
Install 5940 printer without disc
connect the printer to the pc (internet connection is compulsary), then the pc (plug and play (pnp))is automatically guide you. otherwise download printer s/w driver from hp site and install the driver.
Oct 17, 2014 | HP Deskjet 5940 Photo Printer C9017AB1H
Downloaded installation instructions but my mx712 can't communicate with the PC
install the software before connecting the printer usb cable. the nonly connect it when the software asks you to.
Aug 09, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
I want to install printer drivers to a laptop but the printer is in the field, how can I install the drivers without having the printer connected tot he laptop.
You don't necessarily need your printer connected to your PC to install the driver. The driver installation is so that your PC can communicate with the specified printer. If you have the install CD you can install the driver and software. Now Depending on your printing machine, some installation CD's will ask you to please connect your Printer. If this is the case, there really is no way around that because the installation directions wont let you proceed to the next step without doing that.
Each printer and its installation software have different protocols. Some will let you install without the printer being connected, some wont.
I hope this information gives you some clarification on your question.
Regards,
Nico
Jul 09, 2011 | Brother MFC 6490CW InkJet Printer
My computer does not recognize my printer
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
Jun 10, 2011 | Dell 946 All-In-One InkJet Printer
My printer will not install with the software.. it cant detact the printer for the final step
Assuming your are installing this on a windows system and I'm not sure about your level of expertise (sorry I don't know MAC's);
  1. It's a good idea to install the software on your PC before you connect the Printer to the PC (unless the directions say otherwise). Usually, either during the install or when you are done installing the software; the application will tell you to "connect the printer".
  2. IF you connected the Printer before loading your software then go to "control panel" printers and look for your new printer and uninstall it. Then REBOOT your computer. If you don't see your printer in control panel then you may need to go to "Devices" under "My Computer" and look for the printer there then delete it from there.
  3. Now install the software drivers (that came with your printer) on your computer.
  4. When the installation completes, search for new drivers if it prompts you to do so (assuming you are connected to the internet. Sometimes it's a good idea to get the most current drivers from the internet and load these rather than using the software from the box. Be sure to select the correct software/drivers for your operating system. You can run the install right from the internet.
  5. When you are connecting the printer to your PC (assuming you are using a USB cable); Plug the PC directly into a USB port on your PC and do not use a USB hub.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Cant connect lexmark X3550 to laptop wirelessly..
If you are trying to connect to a network printer you need to install a network printer NOT a PC install. You would have to browse for the "Remote" printer, from the CLIENT. The printer that is on the "Master" PC will have to have the printer already installed and "shared" as well, FIRST. Then you go to the remote and install a NETWORKED printer....find it on the network, and connect, it will actually get the drivers from the "Master" PC, see. Plus BOTH PC's will have to have a name password & and be on the same "Workgroup" as well. If you want to enable documents to be exchanged to print between PC's you will have to enable "Sharing" on each, Drive, or Folders as well, if you wish.
Tutorial here http://www.online-tech-tips.com/windows-xp/how-to-install-a-network-printer-on-your-home-or-office-network/
Feb 18, 2010 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Where do I connect the usb cable from my printer to the pc.?
First thing to do install the driver CD of the printer, After the installer searches for the hardware or your printer, plug the printer to the power outlet as well as to the USB port of your PC as shown below, and power on the printer, wait until the installation completed successfully.6278244.jpg
Oct 21, 2009 | HP Deskjet 3845 InkJet Printer
I cannot find a printer to work on Acer Aspire X3200 Vista
any printer will work in your PC...as long as your computer meet the minimum requirement for the printer u choose
before you install the driver..remove or Un install the other program and driver you installed earlier
and restart the PC
you must install the right driver...install the driver that compatible to your Operating System (Xp, Vista), when installing the printer select the right port where you connect your printer (USB, LPT).
they are some installation instruction that you need to install the Printer Driver and Utilities first...then connect the printer or Restart the PC and connect the printer....
goodluck
Mar 16, 2009 | Computers & Internet
When trying to install software for Lexmark x2580 it seems to hang part way through. Heve tried several times from disc, and downloaded software from Lexmark. Message in bottom right states 'a problem...
Hi ,
Definitely u install printer through connecting printer to pc .that's why the problem is occure........
please uninstall of drivers& software of printer restart pc with disconnecting printer from computer...
then install software for printer ..follow the instruction ..then when pc notify u to connect printer/harware detection then connect printer to pc & get printe on ....i am sure u r printer will be detected & install scessfully done
if this information is useful for u please Rate me.........
Jun 14, 2008 | Lexmark Office Equipment & Supplies
238 people viewed this question
jasbo
jasbo
